I have a 1986 Catalina 30 with the M-25 diesel. The last 3 trips I have made, the engine has either stalled out or lost power after about an hour of motoring.
I replaced the primary and secondary fuel filters and all hoses between the tank and the engine. The fuel coming out of the tank looked clean (I drained quite a bit of it out when I changed all of the filters). After doing so, I put in fresh fuel and ran the engine for about half an hour, at least 5 times at the dock. The boat ran fine, and I thought the problem was fixed. The next time out though, after about an hour, the engine started to lurch and then the RPM's went way down. I throttled back to a fast idle and the engine kept running, but whenever I tried to give it more throttle, it threatened to stall. I made it back to the dock, shut it down, and then tried re-starting the engine - it started fine, and I could get higher rpm. This problem only seems to occur when running at cruising speed for about an hour. I've had the boat for 5 years and this is something completely new.
Some possible related factors are: 1) I recently replaced the heat exchanger with a new one (2") and since that time, the engine runs quite a bit cooler than it used to - I assumed that's because it's winter, and the water up in BC is very cold right now - the problems do seem to have started since then, so could it be a temperature issue?. 2) The tachometer is acting strange, either misreading RPM's and sometimes going in reverse - is that a sign of something or completely unrelated?
Ultimately, I'm stumped. I don't know why it runs fine at the dock and for the first hour of the trip, and then starts acting up. The water was flat calm this last time and I had a full tank, so I wasn't stirring up the fuel (and as I say, the filters are all brand new). Has anyone else had this problem, or have any ideas as to the cause?
Thanks
Dave
Thanks
Dave
