Heave to
Quoddy
Apr 1, 2009
241
Hunter 260 Maine
All boats are not created equally when it comes to “heaving to“. On your boat, what’s your procedure for” heaving to”? What’s your boat? How well does it work?
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
My shoal draft '86 Hunter 285 heaves-to fairly well. A lot depends on genoa size. I have and use furling 120 and 150 genoas. If I want or need to heave-to, I first have to roll up the genoa so that it is something less than a 100 per cent of the foretriangle. Heading the boat onto a close reach, I simply tack leaving the working leeward headsail sheet in place and backing the headsail. Once I come about with backed headsail, it is a simple matter to play with the mainsail until it is in a somewhat neutral position with a slight luff. At that point, I turn the wheel/rudder to balance the headsail and the boat will slowly forereach. I sometimes do this while solo sailing and I want to "stop" for lunch. Works pretty well. I come out of the "hove-to" position by releasing the windward headsail sheet letting the genoa come over and off I go.
May 23, 2007
1,306
Catalina Capri 22 Albany, Oregon
Verboten doesn't heave to very well, but she does better with the blade than the genoa. She'l sall all over the lake with the genoa backwinded. With the blade she'll turn up into the wind and tack on you if you're not paying attention. Disadvantages of a fin keel I suppose.
kenn
Apr 18, 2009
1,271
CL Sandpiper 565 Toronto
Our little boat heaves-to (is that a word?) quite nicely under genoa or standard jib.(we have a fractional rig) Having a shortish keel, I imagine we drift considerably, but the boat stays calm and stable, even in a brisk blow.
Bonus heave-to tip: always heave to on starboard tack, so you can yell "starboard" at any encroaching sailboat. :)
Dougo
Nov 22, 2010
82
Hunter 23 Great Sacandaga Lake, NY
My '89 H23 with a stock 110 jib does very well. Beating close to wind, I just come about, leaving the jib alone, let the main sheet out, and tie the tiller to leeward side. She can stay like that all day regardless of any changes in wind speed or direction. To resume sailing, I just let the jib come around to leeward where it belongs, trim the main and off you go. My favorite "move" when I need to break for whatever.
Most boars don't heave to well with jibs much beyond a 110. I agree with Warren, reef the jib if you have a big one. It'll make a huge difference. Why? Cuz you're trying to balance the boat.
May 10, 2004
114
Hunter 340 Bremerton, WA up from Woodland
We have a fairly tall rig with standard main on Starbright and, as is typical with Hunter, a small fractional 100% jib. We follow the standard procedure, as outlined by others, with good success, turning the wheel to weather for balance. In 15-20k winds, we have also had good success easing the main further and bringing a reef in while hove to. I am not sure why this works. We have the deep, wide fin keel witha small bulb. Perhaps there is enough windage on our 340 topsides to partially balance the small jib. In any event, we can luff the main not quite fully and manage to put the reef in without having to turn in to the wind and have the main flogging all over.
Jun 12, 2010
936
Oday 22 Orleans Marina, NOLA
With a 100% jib in winds under 15kts my 22 heaves-to beautifully. At higher wind speeds I need let out the main a bit. I keep the rudder hard over in both cases.
zeehag
Mar 26, 2009
3,198
my formosa sails thru breezes of that strength.... does well at 60+ kts wind also..... LOVE these deep keel ketch rigged cruisers.....
JerryA
Oct 17, 2004
550
Hunter Hunter 170 Sandusky Bay, Lake Erie
My Precision 23 will heave-to pretty easily with good results. It's a lot easier than dropping sails when I need to go below or want to stop for lunch. I usually heave-to as well to put in a reef.
JerryA
John
Jun 3, 2006
803
Catalina 36mkII Alameda CA
jib size
My Catalina 36 heaves to fairly well with the 90% jib I fly. One issue: It does tend to creep forward more than I would like. I always figured if I had a larger jib, it wouldn't do this since the backwinded jib would tend more to blow the boat backwards. From what Stu writes above, maybe I'm wrong?
May 25, 2004
981
Catalina Capri 14.2 1670 Rochester, MN
I don't have any occasion to heave to. There are many boats (power and sail) that spend summer days drifting down river. I just lower sail and drift with the rest of them.
If you have several hard to handle sails and you are only stopping for a short time, than heave to becomes relevant. I used to practice it when I owned a schooner, especially on a first date (Ops ran out of wind, now what do we do?}
