If you are a current or potential user of SeaClear, Open CPN or another computer based chart plotter and have regretted that you didn't have a cockpit display what follows might be a solution for you and one that costs just a little over $100. It gives you a 7" daylight display that with SeaClear will display up to about a 7 mile wide chart area with detail good enough to see water depths and other needed detail. If you zoom the chart all of the way in you can see sharp detail at SeaClear's maximum chart resolution. Running SeaClear in the "AUTOMATIC" mode SeaClear will keep your boat centered on the screen and move the chart under it.
You don't have to be a computer guru to make this work and you just need 12 volts to the display along with a cheap coax cable that can be run over almost any distance. If this interests you then here is the mod...
http://purplesagetradingpost.com/sumner/macgregor-navigation/Comp-ChartPlot-5.html
...and a picture....
.... of SeaClear running on the display out in full sun and ....
....one outside, but just in the shade similar to under the Bimini.
I think this is going to be a good deal for us and make SeaClear just that much better,
Sum
Our Endeavour 37
Our MacGregor S Pages
Mac-Venture Links
Sum
Our Endeavour 37
Mac-Venture Links
