Hello,
This might be more for the Head Mistress forum, but I'm hoping someone else had this issue and can help as well.
'84 Bristol Yachts 29.9. Has an itty bitty 4 gallon rectangular (horizontal) holding tank. Head is Raritan. Plumbing has a y-valve to overboard thru-hull or to holding tank. The tank is in the v-berth on the port. You can see the level through the plastic, if you open up an access cabinet.
The input hose is on the left of the tank near the top, and the pumpout (deck) hose is on the left near the bottom. And, the vent hose is on the right, near the rear of the tank, in the vertical center.
With the vent so low, the tank overflows at less than 3\4 full and dumps through the vent hole and goes overboard. Luckily it was only treated liquid in the tank. Also, the deck hose fills up to overflow (if cap off) as well, even though the tank is only 3\4 full. I'm guessing the tank is getting pressurized from the head, and the liguid is being pushed out the vent and the deck fill.
So, my question is: Is the tank installed sideways? This is a factory install, with the cabinetry, etc being build to hold the tank. Could the builders of an otherwise incredibly fabulous boat have made such in idiotic mistake?
Or is there another reason for the malfunction?
Thanks
Thanks
