Installing Electric Brakes
Sumner
Jan 31, 2009
5,254
.. I was told by the folks at my local trailer shop (who wanted me to spring for a $1000 surge brake job)...
You seemed to be interested in doing the job yourself I thought. If so you can do this in one day and it is all bolt on stuff. If you don't feel comfortable bleeding the brakes once on then just have someone do that.
The only thing you need to have on the axles is the mounting barcket....
...that is on the bottom axle above that I made. The top axle is the stock Mac axle that was on my trailer and has no bracket on it for brakes of any type. If you axle/axles has that bracket on the axle the job is all bolt on, just read how to adjust the tension on the spindle nut, but you will have to do that any time you would re-pact the wheel bearings anyway.
The surge kit above does have the break-away that applies them, so they are legal.
If I lived there I'd be glad to help you, the job isn't bad and if you got the kit I posted I'll bet you could find someone who on an off day from work would do the work for under $100.
Also you can't compare the water that the brakes see in normal highway use vs. going into the water, especially salt water. My truck that I posted a picture of has 150,000 miles with no brake problems until I ran through that salt water a couple times going on and off the salt. Granted it had a higher concentration of salt than even salt water, but you will still get the same effect. Why put on brakes with more moving parts to rust up if you don't have to. If you already have them and want to mantain them then that can be a different story,
Good luck with whatever road you take and any type brake if they are working are better than no brakes or brakes that aren't working,
Sum
Our Endeavour 37
Our MacGregor S Pages
Mac-Venture Links
I'm not saying electric brakes are better and everyone else is wrong.. not at all..
I'm just saying electric brakes are "as good" and not to be afraid of them...
Thanks Squidd: That all makes sense. I priced disk brakes and the kit costs $500 for all of the parts... the electric brake kit cost $185 for all of the parts. And the hydraulics look like they will be more of a chore to install and to maintain. So I'm leaning towards the electric brakes for now.
Sumner
Jan 31, 2009
5,254
. I priced disk brakes and the kit costs $500 for all of the parts......
Ok I promise I'm done posting on this after one last comment.
Complete kit for $381.25 plus shipping. Everything you need...
http://www.blackbearsportinggoods.com/ProductDetails.asp?ProductCode=ELLTIED82101&click=12
...also I posted a link to where the same subject is being talked about....
http://www.macgregor26x.com/forum/viewtopic.php?f=11&t=19686&sid=18b7544f3739ac0b3a9879880da16acc
... before and would like to just quote one response from there...
kevinnem said:
Drum, VS disk.
Disc. I'll never go back to drums if I don't have to.
kevinnem said:
Surge VS electric?
I like surge. Doesn't matter what vehicle I tow it with - it still works, with no other connection to the vehicle.
kevinnem said:
I found a company called "kodiak" that makes entirely stainless steel brakes assemblies, and they claim they are basically 100% anti corrosive with respect to water. anyone use these, or anything like that?
Kodiak, Tie Down, Titan - pick your poison. I got a disc brake kit from etrailer (Titan) for just under $400, with a reverse lockout solenoid, and it's been fine. SS usually has a lower coefficient of friction in braking than CI, but that just means the coupler will push a little harder against the tow vehicle to get the same amount of braking torque at the axle. If you need SS for corrosion prevention, then go for it. I;m in fresh water only, so 'standard' components are good enough for me.
http://www.etrailer.com/Trailer-Brakes/Titan/T4843100.html
Ok I'm done and it sounds like you have your mind made up, but the above might help someone reading this that wants to go a different route,
Sum
Our Endeavour 37
Our Trips to Utah,
Mac-Venture Links
Thanks Sum
Now that the price is not so high... I have to rethink everything and weigh options.
r
