Looking for the largest trailerable sailboat
678
CM 32 USA
I currently have a Mac 25 with a 15HP kicker.
Thinking I want something in the 30 to 32 foot range, to leave in a slip 9 months of the year.
I do not have all the money in the world, so I have been looking at prices more than brands.
Suggestions of a boat that can go down a highway and still be fun on a lake is what I am looking for.
Eyeing Clipper Marines in the 30 to 32' size.
Thanks.
Ross
Jun 15, 2004
14,693
Re: Looking for the largest Trailer-able Sailboat
The size of the trailer sailer is limited only by the size of the trailer and the truck tractor that will be pulling it. The Macgregor is unique in that it is a power boat hull with a mast and sails.
caguy
Sep 22, 2006
4,004
For what you are tallking about the Luger 30 is a good choice. There are links to other Luger owners at my website.
PaulK
Dec 1, 2009
1,384
Sabre 402 Southport, CT
J/24 or Tartan 10 both fit on trailers, though you'll probably want hoists to launch them.
Ross
Jun 15, 2004
14,693
My Islander 30 fit on a trailer!
Oct 24, 2011
258
Lancer 28 Grand Lake
I thought i had bought the biggest trailerable sail boat, a lancer 28, which is a beast when on a trailer. I wont tow the boat myself, as its too big, and it needs at least a half ton truck to haul it, (which i dont have) but, its i would say smaller than the grampian 26 i had, because that had more beam, was roomier, had a deeper draught, but wasnt really the sort of thing, you could put on a trailer. The lancer weighs about 5200 pounds, then you have the weight of the trailer, which at a guess, maybe another 700-1000 pounds. so all in, at least 6000 pounds, which is an awful lot of weight to be towing.
I dont know a huge lot about the regulations, but i had wanted a larger boat, that would have had to be hauled by truck, through a few states, and the price was so much per mile for the haul, then extra which each state charges for a wide and heavy load, on their roads, so it was all going to be too much money. I do know, any boat wider than 8 foot 6 inches, has to have a permit, to move in any state of the usa. But the length is not that important, nor is the weight, (as you are not going to get a boat, that is thirty foot, and weighs forty tons) I think that is about the weight limit for a normal load, A normal truck load, that is, and they pay so much to take that through each state.
Its basically the width of the boat, that restricts you for towing, howevor, the weight will restrict you too, depending on what you are towing it with.
Nov 11, 2009
34
Ericson 31 Independence Lake Lanier
Seaward sailboats made in Florida offers several models that can be trailered. These are shoal draft with the newer models having retractable keels. The Seaward 25 is a good choice for trailering and a big 25' boat.
largest boat
The size of the trailer sailer is limited only by the size of the trailer and the truck tractor that will be pulling it..
We had a Morgan out island 41 moved on a trailer from St Pete to the Chicago area
taichi
Feb 21, 2010
57
Hunter Hunter 23 Oshkosh Wisconsin
My first big sailboat was a Clipper Marine - It was roomy and trailerable, and Bill Crealock designed it so it was a good looking boat. But any Clipper Marine you find out there now will be 45 years old and most likely rotten - Even when new they were lightly built. The sailors arounf me consider the O'day 272 to be about the biggest trailerable out there that's affordable, and a good boat to sail, and can be found on the cheap. There's alot of seawards around me because there used to be a dealer nearby years ago - they hold there value, salty looking boat but with that flat bottom they are very tender compared to most. Look for an O'Day 272 on a trailer
Nov 9, 2008
1,338
Seward 32RK is a nice boat. Trailerable with the right truck. Launches in 20" of water. Not so sure about stepping the mast though.
I trailer my Lancer 25 all over, through the city, over the highway. At about 5000 lbs, it trailers like a dream. I hardly know she's there.
The biggest issue you will have is the size. The limit on most highways and roads is 8'-0 with some going as wide as 8'-6. After that you have to sneak or get a permit. If you get really wide, you'd need escorts too. That's why the Lancers (and others) are built so slim, quite specifically to be trailerable.
taichi
Feb 21, 2010
57
The cheapest Seeward 32 I could find just now was $40,000 - I thought the original poster was on much more of a budget if he was considering an old Clipper Marine - but by all means buy the Seeward 32
Sailm8
Feb 21, 2008
1,750
Hunter 29.5 Punta Gorda
We used to trailer a C22 from St Louis to the Keys. Biggest problem was finding a launch ramp long enough to float off even with and extendable tongue . Just something to consider.
Nov 8, 2010
11,386
Some thoughts:
First beam is a legal issue, but draft is more important. Can you get it on a trailer? Can you get it off? How will you launch it? Lots of shoal draft boat have crappy performance.
Does it HAVE a trailer? If no, adds one will add what, $5000 to the enterprise?
Think about the mast. In most cases you will need a crane. Deck steppers maybe better, but that will be a hairy ordeal.
My pick, is you are OK with the looks, is the C&C MEGA 30. Legal beam and a retractable keel. It's sold, but here is one with a trailer, gone for $7000.
http://www.sailingtexas.com/scc30102.html
Mar 8, 2011
296
Ranger 33 Norfolk
bah. . monohulls. . .
Why not try a folding trimaran? Farrier has a claimed ocean capable folding (trailerable) 33 ft trimaran. You might have to rob a few banks to buy one but. . .it's legally trailerable, comes in at 8'-6" I beleive.
I've seen a picture of a Ranger 33, "True Colors", on a custom trailer being pulled by an old 80's F350. Requires a sling to launch, and crane to step the mast, but it is under 10 feet wide so I think you only need a "wide load" sign to haul it and a trip permit. Not exactly a weekend boat, but nice to be able to take home for winter.
Feb 8, 2007
141
Catalina 36 MKII Pensacola Beach, FL
Check out the Hobie 33
It seems like maybe the most trailerable long boat. May not be super big inside, though.
May 24, 2004
7,164
CC 30 South Florida
A boat on a trailer is not necessarily a trailerable boat. To me the definition of trailerable boat encompasses the freedom of being able to easily move a boat to a distant sailing venue for a recreational sailing trip. I have some requirements for such a boat 1) light so that it can easily be pulled on the road by a household vehicle 2) short or retracting keel for ease of launching and retreiveing in average ramps 3) of a size that meets the road regulations for safety as well as avoiding fines and 4) easy to rig requiring no more than 2 persons. It is no coincidence that boats wich were designed to be trailerables are easier to trailer and rig than those that were not. All boat designs are based on compromises and tralerables are full of compromises. A heavily ballasted boat for stability does not trailer well hence the option of removable ballast afforded by a water ballast tank. A boat that sits low on the trailer will have more options to use availble launching ramps than one that may sit higher. Its all about choices. If you want to keep a boat in the water for 9 months and then move it to storage for the winter months you may not need a trailerable, but if you are gong to hit the road for adventure then choose the one that will best serve the overall needs.
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
I've been amazed to learn how many people actually trailer the model boat I have: Hunter 28.5. One fellow trailers his H28.5 from Arizona all the way down the Baja. With a beam of 10'5," I assume they get an exemption for trailer widths on the highway. Displacing 7200 lbs and with relatively large and heavy mast, this would not be my idea of the ideal "trailerable" boat... as I think you'd need a lot of help at the other end in stepping the mast and getting the boat in/out the water.
caguy
Sep 22, 2006
4,004
Does the C-27 meet your requirements. I can launch and retrieve the boat as quckly as any Mac 26. I tow with an F250 though I could go lighter as long as it has 4wd. Set up is not much more involbec than mya Mac 25 was, though I quickly grew tire of that. Set up was not worth an day sail, though maybe 2 or 3. There is plenty of head room and a head you can stand and pee in.
As far as towablility, I towed it 2300 mile from PA to CA last summer and visited the GrandCanyon along the way. It has a shoal draft keel with a 3-3 draft that requires a 12' extension. The extension telescopes out in less than an minute.
The Hobie 33 is a lot of fun to sail! Weak on livability 'though
