Is there access to the keel bolts on the 8.5? I looked into the hatch below the stairs, and tried to look forward, but didn't see anything. How are the keels attached?
I have two, not counting the manual one located in the cockpit. I have a small West marine something something with a 1/2" or 3/4" hose that fits all the way to the bottom of the sump (attached to an old batten). I also have a Rule 2000 on an automatic float switch, but it only fits about half way down into the sump, before it is too wide to go lower. The boat is very dry, in that water typically doesn't accumulate in the bilge - I use synthetic packing so the shaft log doesn't drip, and I never put ice in the fridge so it doesn't drain to the bilge either. (I've insulated my sink, so all beverages go into the sink for the day, covered with ice, which drains to the thru hull. I also have a adler-barbour refrigeration unit.))Thanks for the pics. What kind of bilge pump do you use?
