Battery box?
ami342
Oct 21, 2011
21
Oday 22 ft. Cocoa, Florida
Hi Folks, Does an Oday 22 owner know where the battery originally was located ? I have a wiring nightmare to wake up from on my 22. There should also be a common ground for all lights, but I can't find it
One other thing, I have Xantech cabin lights, low and high (1157 bulbs)
Are the lights still made and has anyone found the lenses for them?
Jun 9, 2008
1,860
- -- -Bayfield
1157 bulb is the same bulb used in trailer lights.
I believe the battery location was down in the cockpit seat locker area.
Can't help you with Xantech lights.
Jan 24, 2005
4,881
Oday 222 Dighton, Ma.
Usually the feed wires that attach to the battery are made up of a large conductor like for instance a #10 stranded copper with a large crimped on eye connector on the end. If you can find something like that in a black and red color, that's probably the area where your battery is supposed to be located. A good place for a battery is under the center of cockpit floor in the cabin. What they usually do is have two metal straps screwed to the cabin sole plate under the cockpit with a Polypropylene belt type strap going through these metal hold down straps. The battery is then placed in a plastic battery box with a lid and the Poly strap secures it to the sole plate so it doesn't move around. This is the way mine is set up on my O'Day 222 but yours may be different. Just find the ends of the largest wires and that is probably where your battery was located.
At the electric panel, all your grounds should be tied to one of those wires, probably a large conductor black wire. The feed wire coming from the battery is probably attached to a metal buss bar which feeds the individual breakers for your lights and accessories.
Wiring always looks complicated until you figure it out and the best way to do that is with a Volt/Ohms Meter and a basic understanding of a DC circuit on a boat. All that's involved is a hot wire and a ground.
On my boat there's a black and red wire going to each light and all the blacks are tied together to the black wire coming from the battery. The red or hot wires from the lights are connected to the breakers coming off the the buss bar in which the Red wire from the battery is connected. Take your time and study it. I'm sure you will be able to figure it out once you look at it closely.
936
Oday 22 Orleans Marina, NOLA
Here is a before pic of my wiring...
So I built a panel, ran the battery wires from the locker to it to feed the battery selector switch, then that output to the bus bars - they drive the breaker panel and any direct outputs - like the VHF, inverter and Cig litghter - each which has an inline fuse. The electircal on a 22 is not very complex and I opted to just start over...
Jan 24, 2005
4,881
That's a nice neat job Ken. I like that. It's set up better than the factory set them up. If you ever develop a fault on any circuit it will be easy to remove the pair of wires and ring them out without having to untie a bunch of grounds.
Mine is like an electrician's nightmare. A guy could get a headache just looking at it. :eek:
sPk
Jun 12, 2005
111
Oday 25 Apostle Islands, WI
You can get some 1157 base LED bulbs that fit into original sockets. I purchased one and will be getting more. They even work low/hi and use much less power.
sPk
