As the subject line says, I am getting a new motor, new batteries, and a new charger for my Lancer 27. So where do I need the help? Read on.
My old motor was a '95 Yamaha T9.9 that gave up the ghost. I am sure it would be a simple fix but confidence is low. So I am purchasing a '12 Yamaha T9.9 to replace it. Same fit, form, function, except... this motor is electric start. The previous was manual start. Ok, that is the first part.
I am also getting a new battery charger. Guest 16102 12 amp 2 bank charger. i think that is all I need for shore charging. My electrical budget is not that big on the water. So I went with a smaller charger to replace the burnt out Xantech 20amp 2 bank charger. Ok, that is the second part.
I am also putting in new wet batteries, 2 group 27. this is what I had before and worked well. So basically nothing changed there. My previous batteries fried when the charger fried. Which fried first I have no ideal. But I am sure it was something I did or didn't do.
Here is where I need the help. If I still had the manual start motor this would be a no brainer. But because I am now putting in an electric start motor, I need to know how to wire the motor into the batteries or battery switch. The last motor had one wire connected to a battery isolator and it was connected to the two battery's POS posts. Will I do the same thing or connect the hot wire to start the motor to a single battery or to the battery switch?
I am not sure of the wiring for this. I will be home again in December. The new motor will already be installed and tested. Any advise on how to wire the new motor to the batteries would be appreciated. Maybe all I need is to connect it to one battery and call that the starter battery.
Thanks in advance.
I have added a diagram to what I think is correct, but not 100% sure.
Thanks in advance.
