Hanging Out and Hooking On
3,562
Endeavour 32 Portland, Maine
Yesterday, I crossed a psychological line. I’ve been pushing hard to get there and I suddenly realized that “there” has become “here”. Even with Delaware Bay ahead of me, Cape May is so different, interesting, and so much a part of the world I was anticipating, that I’m doing like the new age bumper sticker says, right here, right now.
My Victron monitor told me that the batteries were low so I ran the engine. This got it nice and hot so I was able to do the oil change that has become a bit overdue with all the pushing on. The previous day’s wind shift resulted in my ending up riding to my Fortress stern anchor which did a great job although with anchor rodes running all up and down the length of the boat. I wanted to get things simplified and my main anchor out in front. Wind and tide were running together so, waiting until just a bit before the current change, I winched myself up to the Fortress and pulled it aboard.
I don’t have a windlass but threading a block snap shackle block on to the stern anchor rode, hooking it to the midships cleat, and cranking the rode on the two speed jib winch worked very well. I brought the Fortress back to the stern as Strider blew the nearly 400 feet downwind to fetch up on my Delta main anchor. Pat myself on the back for the foresight to loop a line around the main rode at the quarter so it couldn’t go under the boat and anchor me by my prop or rudder. Strider rode briefly by the stern cleat and I simply cast off the end of the loop around the anchor rode and wind and tide swung her into position.
Several boats had left and there was a better spot up wind so I warmed up the engine and began winching myself up to the main anchor. I didn’t want to cut the lashing in the anchor locker and bring the bitter end up on deck to winch as I had the Fortress so I used the main halyard winch. (Note to self: Buy a snatch block the next time you see one in a marine store.) This works well but is a smaller single speed. My winch arm was getting a bit tired at this point so I gave the occasional gooses forward, enough to slack the line but not run over it, and then pulled in line and winched quickly before she lost the momentum. It was a lot of running back and forth but I can use the exercise.
Good holding ground in Cape May. Both anchors were a bear to break out. I have a tackle with a S.S. reefing hook on it that I lead back to either the mast or the midships cleat and use to pull on the chain once the shackle is over the fairlead. It took a lot of sweating on the fall as well as some running ahead with the engine with the bitter end secured to break each anchor out of the mud.
I had the current timed just right. The Delta went down and I was able to back straight back to 14 times the water depth and let the Fortress off the stern. At slack water, I was able to hand pull myself up to short scope on the main anchor and give the Fortress a good set by pulling against it. I then let the main rode out to the proper scope and pulled myself back in to my final position before the flood started flowing hard enough to make this a chore.
Speaking of anchoring, one of my concerns about the cruising life has been the lack of cable, the TV kind. However, the widespread cluelessness about how to anchor a vessel has been providing all the entertainment I could wish for. The day before yesterday, I looked out to see a late model Hunter, with every bell and whistle that a broker could ever bundle into a sale, drifting rapidly down on my friend’s motorsailer. The Hunter powered away just in time and then tried again in several spots. The basis of their method seemed to be that other boats must be in good holding ground so the places to try were 2-3 boat lengths directly upwind of ones that were already secured. Eventually, they gave up and headed off towards the marinas.
I woke up early yesterday morning to see them anchored right out in the middle of the channel. Several of the tugs going back and forth between the port and the major dredging operation would pass them about 20 feet away blowing their horns but nobody took the hint. Eventually, a Coast Guard officer speaking down from the imposing pulpit of a 47 foot utility boat got the message across. Up came the anchor and the fun began.
They were now using the “Fishing Method”, after all, it’s a hook, isn’t it?. The anchor is let out over the bow just enough to skim over the bottom and the boat driven around the anchorage with the person on the bow waving and pointing in different directions until some resistance is felt. This technique can work when there are old mooring chains, power cables, or abandoned ground tackle on the bottom but has the disadvantage of the anchor being a single use item. It wasn’t working for them in Cape May but I appreciate the intelligence that most of the anchorage is apparently clear of cables.
After about the eighth attempt, and waving them off from trying the spot directly over my stern anchor, I got in the dinghy and rowed over to ask if they could use some tips. They said, “Yes”, and added that they couldn’t figure out what was wrong because they were using twice as much chain as the water depth.
If I had a printer on board, I think I would now make up little cards to hand out:
Pick your spot and stop the boat dead. Look at the shoreline landmarks to be sure you are motionless. Let the anchor out until it just touches the bottom and wait until the boat starts drifting back. Try to let the chain out at the same speed the boat is drifting back until you have out a minimum of five times the water depth. Let the chain lay out along the bottom and stop it when you get the right amount out. If it’s windy or there is strong current, let out another amount equal to twice the water depth or a bit more.
They thanked me and I watched them head off to try again. They went for the first spot they tried and I heard someone yell, “We tried here and it didn’t work.”
“Yes, but that fellow told us how to do it.”
Sure enough, they were soon secure in that exact spot and haven’t moved since despite brisk winds and strong current.
I was woken this morning by voices alongside and looked out to see a large Morgan center cockpit ketch trying their luck at finding the elusive magic spot. Their mizzen set in a wind against current situation wasn’t making things any easier for them and they were using another tried and dis-proven method. They would find their spot and get the boat stopped, one point for that. Someone would yell, “Let go!” and what sounded like the proper amount of chain would run quickly out, another point for that. Then, as soon as the boat began to move back and the bow man could hear the links rattling over each other as the chain straightened, he would yell, “WE’RE DRAGGING!” The windlass would start winding (there’s a reason why those of us without them learn to do it right the first time) and they would soon be off to another spot.
After about eight cycles, they decided to try about three boat lengths upwind and abeam of me. I dressed quickly and got into the dinghy grumbling to myself, Who appointed me to this job? I rowed over in the dark and yelled to the fellow at the wheel, “Look, this is very good holding ground. Your anchor will set the very first time, every time, but you are going to be doing this all day the way you are going about it.”
I then said (see my “card” above) “and besides, you are in the channel and the Coast Guard will probably ask you to move later. I suggested a spot and they headed off to it where, from what I could determine in the dark got a set the very first time. It’s one of those rare things in life where doing it the right way actually works, most of the time.
Shortly after, I turned on the radio to get the weather and heard them negotiating with the Coast Guard for evacuation of a crew member with a crushing injury to the wrist and the boat showed up a few minutes later. The fellow who went by later with the splint on his arm looked like the anchor handler so I suspect their anchoring learning curve was steeper than most. Raising and lowering it six to eight times instead of once just increases the chances for things to go wrong, especially when tired after a long night passage.
Anchoring didn’t seem quite so amusing after that but I’m sure that will pass and it will be a constant source of entertainment as I continue south, just as long as no one blows into me in the middle of the night.
3,562
I just learned on a row around the anchorage that the injured fellow was indeed the anchor handler who let the chain drag his hand into the windlass. Why he had his hands on it with a windlass, I'm not sure.
He was injured on the attempt right after I had offered my advice because, of course, that was the first time the anchor set and the chain came tight. This being America, I'll probably now be sued as the proximate cause of the incident. If I'd kept my mouth shut, the chain never would have come tight and the boat would be in a marina now.
Jun 2, 2004
5,802
You are right Roger, your posts are much more entertaining than any TV programming.
Kind of a shame that you got to Cape May so late in the season. There is so much to see and do in the Chesapeake and North Carolina. But it is going to get cold. Probably already is in the cockpit with the wind blowing.
Oct 1, 2007
1,865
Sorry to hear about the guy getting hurt. I did something pretty dumb once and this caused it to pop into my mind. We were beating to windward just north of Seguin I which is a rocky scary place under any circumstances, but in a fresh breeze going to windward, it is more so. I ducked below for a sec to get something and I picked up the floor board near the companionway, as I always do, to check the bilge and found it full of water !!! We were motor sailing at the time so I instinctively dipped a finger in the water to taste it, and wham !!! My finger was struck by the set screw on the shaft coupling. Split it right open. What a mess. Of course the good news was it was fresh water from a tank leaking. Well, I learned a painful lesson there. Ever since then I have been terrified of spinning shafts. :cry:
On the anchoring, to me it is always much easier to anchor if I don't happen to be the one anchoring. That is, especially in a crowded anchorage, I am always nervous about getting it right the first time. However, when I am already hook down and relaxing, I find it so much easier to see where the boats are, their anchors are, the wind, etc, with the boats dancing around. I always find it so much easier to see the open areas, and where to drop a hook to lie just right. Although that's the case I never give advice to new boats, except one time. If they ask I will tell them how much scope I am riding to, but that's it. This is also true about navigational advice. I just don't give any to anyone, even if they ask. I just don't want any responsibility. One time I did make an exception though and it worked out just fine. One time we were in Cuttyhunk late in the afternoon with a front coming through and a forecast for NE the next day. Now anyone who frequents that harbor knows you want to be inside the inner harbor in NE. So an elderly couple with a dog aboard a 35 ft something came by with near panic looks on their faces as the inner harbor was jammed and they couldn't see a spot to anchor and they were looking like going outside. However, I could see a perfect spot not far from me where they could fit nicely. So I hemmed and hawed and finally suggested they drop their hook just astern of such and such. Well, they did and it worked out well. They rowed over after with profuse thanks on their way in to walk the dog. But, as you can see, sometimes it doesn't work out as well so I abstain from advice of any type, either asking or giving. Unless of course I'm asked about the bars in town, then I'm full of advice.:neutral:
Bob J.
Apr 14, 2009
775
Sabre 28 NH
I've enjoyed reading about your trip heading south & sounds like your having fun.
As far as the cold, folks haven't figured out that us yankees don't even roll the window up in the pick up truck till it's at least 20 outside & then we only roll it up half way:)
Keep the trip stories coming, be safe & enjoy!
May 24, 2004
7,226
CC 30 South Florida
Hard to believe they are still dredging, we were there over two years ago. Our plans to reach Cape May by sundown had been thwarted by the tide as we could not make the 55' bridge in the Canal. We decided to go out and anchor for a few hours and wait for the tide to go down. At around 11:00 PM we decided to try again and now we could feel the outgoing current pulling us toward the bridge but still needed a few more inches of clearance. We motored in circles and around 12:00 PM decided the numbers were right and joined the outgoing current. We cleared the bridge by about 6 inches and moved on to the next one. We were soon out of the Canal and unto the basin which we faced with utter confusion. All the dredging markers and all kinds of lights made the scenery confusing. Combining the info from our chart plotter with marker observation and slow speed we crawled our way into Utch Marina. (no easy feat at night) We tied up at the fuel dock and were soon asleep from exaustion. Promptly around 7:00 AM we were greeted by the dockmaster who was unlocking the pumps. Garacius fellow as he even brought us each a cup of coffee. When we left Cape May in daylight the layout of the Basin became obvious and simple. Have visited many towns but Cape May is very interesting and picturesque.
Nov 22, 2008
3,562
I'm wishing it was a bit colder. I'd like shower so I have the cabin heater going to heat up the water tank and I'm too warm even with the hatches open and dressed like I would be in high summer.
Apr 22, 2001
497
Hunter 420 Norfolk, VA
Be careful what you wish for, Rodger... :)
As you come down the Bay over the next few weeks, I suspect you may have occasion to roll the window up ... well, maybe half way, anyway...;)
BTW, I, too, am enjoying your blog... great writing.
I'll be leaving Norfolk, (about Thanksgiving), also heading South to Fla.
If, by chance, I happen to anchor near you one afternoon, I promise to have a copy of your anchoring "suggestions" w/ me ... :) ... and ...
if you don't laugh at me too much, I'll "buy" you a beer.
TomY
Alden Forum Moderator
Jun 22, 2004
2,769
That was a very kind thing to do.
Mar 20, 2004
1,753
Be careful what you wish for, Roger! it's snowing up here!
Fair winds,
Chuck
