Thought I'd post this if anyone is interested in having pressurized water on their small boat.
I put this system in my previous boat, a Precision 23 and now in my 26.
I wasn't happy with the pumps on my O'day 26, awkward and hard to wash up while one hand is on the pump.
I cut the water line going to the cabin sink and put a windshield wiper pump in line. I used a 1999 Honda Accord pump @ 15.99(just because that's what I drive), you could probably use any, you'll need a hose or two to adapt to fit the hose on your boat.
I ran one wire to the battery and the other to an on/off switch I installed at the sink.
I also put a shut off valve in line with the pump to keep the flow down, I found I was using a lot of water. With the shut off, you can dial in the exact amount of water flow for your needs.
I used a plastic 5/8 shut off valve with a threaded 5/8 to 1/2 hose on each end.
The entire project cost around 25 dollars and works really well.
John
John
