How many on board or weight??
13
Catalina 30 MkII Lake Murray, SC
I just purchased a 1984 "25" and need to know how many people it can legally carry or what total weight. I am new to sailing and am looking forward to learning what I should do.
Thanks, Al Cox
r.oril
Oct 29, 2008
586
MacGregor 26D and Catalina 30 26 - 30 Lancaster, CA
Check the manual in Boat info above.. Says 5-8 adults. Have PFD's for all onboard.
I have had 3 adults and 2 kids on my 26D with no problem.
Kermit
Jul 31, 2010
5,722
Are you taking lessons from Brian Adams? The ASA course book will answer that question. I'll look up the numbers for you in the morning if you don't have the answer by then.
And welcome to the wonderful world of sailing!
Kermit
LuzSD
Feb 21, 2009
1,009
Catalina 30 San Diego/ Dana Point, Ca.
I stopped at the new to sailing line........ with a 25, I would hope you'd stay with 2-3 until you are really comfortable with your boat and your skills. We recently had 6 on our cat.30 and we sail alot....... 2 were not sailors and it made it very crowded and difficult when heeling and tacking were involved. I think your question is much more loaded than you realize. take it slow....... be safe.
Beneteau 323 Annapolis MD
A 1984 probably does not have the label that new boats do. It would give a number of people, but that number is most likely there to limit the manufacturer's liability in case of a lawsuit. I can't see any weight capacity rating as being logical, as how would you weigh everything/everbody everytime you went out? Otherwise, there is a formula (that no one seems to know the origin of) length times beam divided by 15, the result being the number of people that COULD be on the boat, though probably not safely or likely.
Jun 1, 2004
8,323
The question should not be how many people it could carry LEGALLY.... but how many it could carry SAFELY....
Never carry passengers without the water ballast tank filled.
Jan 26, 2011
24
Beneteau 323 Manly Queensland Aust
That would mean 24 people on a 323:)
Kermit
Jul 31, 2010
5,722
OK, here's the answer. Length x width / 15. The answer is 15 people *legally*. Actually, that's a crazy number unless you're smuggling people from Richland County to Lexington County. Just make sure they're all wearing Coast Guard approved PFDs. My boat can *legally* carry 12 people. But in reality, 4 is the absolute most that is comfortable. 3 is even better.
Start slow and have fun.
Kermit
KD3PC
1,069
boatless rainbow Callao, VA
Wait until after the HOS lawsuit is settled, I am sure there will be a discussion about this very question....
Until then..4 or 5 would make a lot of sense.
Jun 6, 2006
6,990
So, using your formula my 40.5 can hold 32 people!!!!!
At 16" width per person that would be 42 feet of rail meat which works fine as I have 41 ft of toe rail and I can stand at the helm.
Kermit
Jul 31, 2010
5,722
That's the formula that came from the ASA study book for Keelboat 101. I never said it's a great idea. In fact, I said it's crazy.
Kermit
1,096
CS 30 Toronto
"Never carry passengers without the water ballast tank filled."
Mac25 has no water ballast tank. It uses an iron swing keel with a winch underneath the companionway.
Oct 10, 2009
1,100
Catalina 27 3657 Lake Monroe
I think there is a difference between what a boat can "legally" carry and what is safe. For those new to sailing, the best number is less, rather than more. People who don't sail have to be told where to sit, what to do, etc. and even compared to a new sailor, they require a lot of attention. As the skipper their safety is your primary concern and when the wind pipes up and things get more complex, the skipper's job becomes harder.
If you're going to motor over to a cove, drop anchor and swim, the situation may allow for a few extra people on board. Or, if it's light winds and easy sailing, you may feel comfortable with more people. Ultimately, it's up to the skipper to take conditions and skills into consideration because once people step onto your boat, they are your responsibility. My wife and I have conversations about this quite a bit. We love introducing friends to sailing, but with a small boat we are careful about minimizing the risks involved. More than four is pushing it for me, but I make exceptions if the people have sailed before, or if it's a couple of neighbor kids who we've taught to be safe on board. It may seem overly cautious, but I'm not a seasoned sailor and I try to stay within my skill level.
Kermit
Jul 31, 2010
5,722
You never read about overly-cautious people in the news. Best to keep it that way. Use common sense. And *always* have all the required safety gear.
Oct 10, 2009
1,100
2 people died when this tour bus flipped.
And this case ought to serve as a warning to sailors. Too many people, poorly maintained boat, not enough pfds.
That particular boat was also a MacGregor, but it was W/B.
Link
Kermit
Jul 31, 2010
5,722
I couldn't help but shake my head when I heard a new member of the Coast Guard Auxiliary bragging on his new inflatable PFD. He said, "It'll be good to have so I can wear it when I'm out fishing by myself or something." He told us he doesn't wear any type of PFD when he's with someone because it's not required. I always wear mine. Just takes the trying-to-keep-your-head-above-water-when-you-fall-in issue out of the picture. And they are totally comfortable.
