Some of you know about me rebuilding the YSM12 for my C30. I ran it for a couple of years, put about 50 hours on it and decided to rebuild a 2QM20 to replace it. I sold the YSM to a forum member here at SBO that lives in Houston. He drove up to pick up the engine and he, his friend and I took it out of my boat loaded in his truck and he took it home. Actually he took it to a mechanic to make a custom exhaust elbow, buy some motor mounts and touch up the paint. I hadn't ran the engine in 6 months or so when I went to the boat to meet the buyer and take the engine out. As always it started up right away. Understandably the buyer wanted to see the engine run before buying it.
We were standing in the boat, I was getting ready to shut down the engine, I shut the water off, went to throttle it back and shut it down. One of the guys said "can you just back it out and turn it around under power". I said sure. I went up to back the boat out. Smoke started coming from the cabin and I realized what I had done. I went down and turned the water back on. The temp gauge said it was still normal temp, about 20 degrees above what it usually ran at. We waited 20 minutes with the engine running to make sure water was flowing through the exhaust again and clear out the smoke from the cabin. When we started taking the engine out, the exhaust elbow fell apart at the solid part near the engine. It just literally lifted up like it wasn't connected. We looked in the elbow, it didn't look corroded but something was obviously wrong with it.
The mechanic has had it for two months or so. Yesterday he said the motor was locked up and took the head off to see why, and this is what he found. He claims the motor had been submersed in water prior to him receiving it.
The buyer says there are no engines outside at the warehouse.
The buyer is going to the mechanics shop tomorrow to talk about it. The mechanic is under the assumption that this engine looked like this leaving my boat. I don't believe an engine could run like this or any where near this condition.
I thought it was astronomical odds that this engine ran flawlessly for 2-1/2 years and the moment I am standing there selling it, the exhaust elbow broke off. What else could have happened to this engine immediately after running perfect for 2-1/2 years, we turn it off and now it looks like this two months later? Cracked block or cracked head as we shut it down?
In your opinion what happened to this engine?
