Now I went and did it...
Squidd
Sep 26, 2011
890
AMF Alcort Paceship PY26 Washburn Wi. Apostle Islands
I think I bought a boat, OK I know I bought a boat, but I want opinions on whether I can use it as a "Trailer Sailer" or would be better off renting a slip for the season...
26' 1978 AMF Alcort Paceship PY26...Swing keel, (2'7" draft) 6400# dry
I know it's on the big end of TS's but want to hear from others that are pulling a bigger rig...
Plan is to build a "drive on" bunk trailer w/extendable tongue for ramp launching...
Has stepped mast to keel, has anyone converted one to cabin stepped with centerpost...? (for easier on shore rigging) ?
Will have more questions as I go along...
MrUnix
Mar 24, 2010
626
Hunter 23 Gainesville, FL
From info gathered on the net, it looks like that boat eventually morphed into the Tanzer 27, so you could probably look at them for ideas on the mast.. the T27 is deck stepped. Should give you an idea of what you will need to do to convert it and what kind of bracing you need down below. As for towing.. good luck! That is a pretty heavy hunk of boat to be towing around and a largish pull vehicle will be required, not to mention a nice deep ramp!
Cheers,
Brad
Squidd
Sep 26, 2011
890
I know it's on the big side, but I have a one ton dually 4x4 with 454 bb to pull it, and have been a professional welder so building a low slung, slide on, bunk trailer shouldn't be a problem..and most ramps will be on Great Lakes (I live near UP with Superior and Michigan less than 2 hrs away)
However I have all winter to ponder the possibilitys and make arrangements so a once a year or twice a year haulout with slip rentals may be an option.
I'll look up Tanzer and see what I find...
Nov 6, 2006
10,247
That is a fine boat, Squidd.. I remember sailing on one when they were brand new.. Well built .. You sound like ya have it well in hand.. A proper tow vehicle and a way to make a useful trailer. Best to ya.
Edit;
The 9.5 foot beam may be a problem with trailering ??
Squidd
Sep 26, 2011
890
Yep, I'm not unaware...working on that now as I decide if I'm going to pay a professional transporter and let them deal with intrastate regs or go out and haul it back myself...So far looks like all I need is "wide load" signage and daylight driving hours (which is fine with me) and a low cost on line permit.
Not looking to go out "every weekend" on this boat more like 4-5 times a year planned "mini-vacations" to make it worthwhile...
Harbor mooring or slip rental may be an option...but I hope it's not my only option...
Nov 6, 2006
10,247
Figured you were aware of that.. At about 32 degrees angle of heel, it becomes 8 ft wide.. I have seen some pretty big stuff trailered while "heeled" on a custom trailer. but if the sinage and daylight hours is all, probably not worth messing with. Again.. nice boat..
Squidd
Sep 26, 2011
890
I'm likeing that...For my first trip home I'll need to build a temp cradle anyway and heeled over saves on several state OW permits and hassle...
Then when I get it home I can build a more "upright" and stable platform for moveing/storage...
Thanks
Rick D
Jun 14, 2008
7,206
Just A Thought
A trailer would be great to expand your cruising horizons, and from your description of your vehicle & skill, not a huge task. You will be using it off the trailer for longer cruising, so it doesn't need to be as easy on/off as someone who is using one for daysailing.
I also assume you have a ready and reasonable place to store the trailer, so one thing you may consider is a seasonal or month to month rental of a slip or mooring so you can use her for daysails and overnighters. That way you can have the best of both worlds.
Easy for me to spend your time & money. Enjoy! Sounds like a good boat.
Jul 1, 1998
3,062
Bottom Paint Toxicity
One thing to check into is bottom paint. If the boat is only in the water for a short while one can dry sail her without bottom paint. But, if one goes longer then bottom growth starts to take hold.
On the other hand, if bottom paint is used, and what I'm more familiar with is Petit Trinidad, then what the paint really likes is to stay in the water. If it is out for a few days the paint starts loosing it's toxicity.
Maybe there are some other routes one could take with regard to paint that don't have that problem. I haven't kept up with the new formulations so there might be one that doesn't have that issue.
Using California as an example, Washington state is banning copper based paints in a few years so perhaps the Greats Lakes states will be doing the same thing, if they haven't already.
Something to think about.
P.S. If you're only going to sail her a few times a year, what about using a travel lift for launching and retrieval? It'd cost a bit more but save getting the trailer rusty.
Squidd
Sep 26, 2011
890
Yeah, we'll have to see how it goes...
I'll be Great Lakes fresh water, so not as aggressive a medium as salt but loading a boat of this size and weight will take it's toll on the hull as well...lots of compromises/balances here...
If it ends up to be too much hassle hauling, masting, rigging and launching... I may go to a slip or harbor mooring for a month...then move to new spot and slip it there for a month... that would certainly allow for more sailing time..
I'll have to try it and weigh the difference in convenience vs cost...I got more time than money...
Big thing will be if I can do a "deck step" conversion on the mast...or need a rigger every time I launch or come up ...
Oct 26, 2005
2,057
- - Satellite Beach, FL.
You might want to ping on the O'day guys, there is a 23' pop top model where the entire cabin top raises and this one has a keel stepped mast. IIRC, either O'day or an aftermarket firm has come up with a tarbernacle that is located above the level of the popped up top and this might work for you and your boat.
Nice boat, congrats!
Jun 1, 2004
8,343
To me the only issue is the keel stepped mast. All the other issues seem to be something you can adapt to with your welding skills. Stepping the mast will require a crane to lift it 6 or 7 feet. I'm not sure if the classic, home built, A frame system will provide that much travel. What this means is that you'll have to find a crane, ez lift, or a bridge to get the mast up.
Converting to a deck stepped mast could require considerable modification to the cabin top.... I'd recommend MrUnix' advice regarding the Tanzer 27 to get an idea what you'll need. But if you did that, and installed a hinged tabernacle, rigging up an EZ mast stepping system will give you more use options.
You can have a lot of fun with the boat right now by simply finding a launch area or yacht club with a crane. Leave it in the water for a few months, then haul it home for the winter.
Squidd
Sep 26, 2011
890
I will have to check in with the marinas in the Bayfield area to see what the rates and crane availabilty is for that sort of rigging service, vs modifications (if doable) to the mast/step. I'm just hopeing to avoid a full blown "haul out" every time I want to launch my boat...
@merlinuxo, thanks for the tip I'll start a search on the O'day mods...Aluminum welding is not a problem...
Jun 29, 2010
1,287
Moving from slip to slip is probably going to be an issue. I am not sure if the folks up there in Bayfield are OK with that sort of "Contract". When I was poking around for that sort of thing I know that there aren't a lot of places to keep your sailboat on Mile Lacs or Leach lakes in MN either. No clue on the two Red lakes in MN. Also, from what I have heard, Bayfield is not cheap either. I heard in the range of $180 - $200 a foot for the season plus storage, FWIW hearsay of course...... Have you called Pike's Bay or any of the others up there on availability? There could be a waiting list as that area is very popular. "Princess of the Lakes" on here keeps a Hunter up there in Bayfield, she would be a great resource for information.
Squidd
Sep 26, 2011
890
Yeah, Bayfield is kinda high end "touristy" but there are neighboring communities that may be affordable...
I just saw a conversion "hinge" that may work so I don't have to keel step the mast...
http://www.com-pacyachts.com/mastendr-mastraising.html
That's what I'm looking for now just need to see if it can be retrofited to my rig...
Yes, I've seen her profile, I'll have to contact her to get the ins and outs of the local dockage...
Oct 26, 2005
2,057
If you'll look at the pic below of a "Nimble Kodiak" it has something like what I think the O'day guys are doing. The upright that is supporting the stepped mast just forward of the house is the lower mast and tabernacle. I think this style comes from Northern Europe and people sailing canals the don't have draw bridges.
Esentially, you cut your existing mast above deck level and install a hinge mechanism. This alleviates any requirement for structural changes below deck or in the deck as the mast is still supported at the keel.
Good luck and let me know how it goes, however you tackle this. I like to hear about innovative boat fixes. I'm funny that way.
Just saw your post with the compac hinge, very cool!
929
I trailered my San Juan 7.7m home from KY to OK. It's 9.5ft wide. I looked into all the different requirements of all the states that I would have to drive through, and I decided just to drive it home. No escorts, no flags, no "Wide Load" sign. I felt the sign would just put a target on my back. I stayed off the interstates too. The boat/trailer was 9.5ft wide and 12.5ft tall. It was quite intimidating and first.
The biggest issue I had was some stupid kid parked is car in front of me at a gas station, he forced me to stop with the trailer still in the hiway. I had to back up, when I finally got in to the station I couldn't get to a diesel pump. Then some other folks blocked me in, so I just had to sit there and wait to leave, never getting any fuel. I had one narrow bridge where a small car went by me, the toe rail may have passed over the top of the car, it was tight.
There were two gentlemen that helped me when I picked up the boat. They have boats wider that 9.5ft, and they stated that they trailer them often and have never had any problem. Seems odd to me that they would trailer such a large boat very often. They said that they trailered them so they could race them in other locations. I saw one of the boats on it's trailer and it was large, it had a retracting keel. These guys seemed to have some money.
Sorry for all the rambeling.
Squidd
Sep 26, 2011
890
Someone gave me a calculation that if I heel the boat 32* on the trailer, it'll only be 8' wide and I can skip all the wide load hassle (at least for the cross country trip home)
Then once I'm here and get it on a glide on trailer, I think I'll pay the $20 or so for the permit and run the flags.. It's really not that big of a boat compared to some campers and motorboats I've seen on the interstate...
Al1653
Catalina 25 Tall Rig/Wing Kee Houghton, MI
I've had a Catalina 25 with trailer for 24 years. The trailer has saved me thousands in storage fees since I am able to launch and retreave and the local ramp and I can store the boat in my yard. While it is not big deal to pull the boat a few miles to the ramp setting up the boat is a chore I do not relish. It takes at least three hours and sometimes four to set the boat up. You would lose a half day of hard earned vacation just setting up your boat, and thats if you don't run into any glitches, which there usually is.
You might also check the road restrictions on load width. In most states you need a permit to haul a trailer load wider than 8 feet.
I would look for a marina that offers dry storage which allows you to store your boat on the trailer with the mast raised. This is a much cheaper option than a slip and much less hassel.
Al1653
Have you checked into the marina in Ashland WI? It's only a few miles from Bayfield, much less crowded and I'll bet much less expensive.
