No raw water going into head...
4
gina laura phoenix freeport,ny
Hi,I'm new here and have a problem with my Raritan PHII head. The water flushes out of the bowl fine but no raw water is filling the bowl. There are no obstructions in the hose and have water up to the pump.Any ideas what to check ?,the unit is only a year old.
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
do you have the valve on the head set on wet or dry...
regards
woody
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
Its in the wet position.
hummmmmmmmmmmm thats all i had to offer ...sounds like you need the expert.....the head mistress can fix anything when it comes to tolits on boats ...she should be alone some time today or tommorow for sure...
regards
woody
May 24, 2004
470
Hunter 33.5 Portsmouth, RI
Just one thought, You did check that the sea water intake sea cock is in the open position (the thru hull valve)?
Oct 6, 2011
4
Yes,I have water all the way up to the pump.It was working until I put some tank deoderizer in the bowl instead of the holding tank.It worked for a little while and then the water stopped.I'm guessing it might of swelled a rubber seal or something.
Dec 2, 1997
8,975
- - LIttle Rock
Make absolutely CERTAIN that the "dry/flush" knob...
Is turned ALL the way to flush mode. If it's only part way, you'll get little or no flush water.
Check all the holes in the underside of the rim of the bowl...it's possible that a sea water mineral buildup has clogged 'em. To check whether the problem is in the pump of the bowl, remove the hose from the bowl and flush pump the toilet. If there's a blockage in the bowl rim, water will flow out that hose.
Which brings me to another thought: I don't suppose you've just finally gotten around to installing a vented loop in the intake--which should have been done when the toilet was installed--but put it in the wrong place (between the thru-hull and the pump)? 'Cuz if you have, the pump will have a hard time priming, which would prevent your getting any flush water.
If none of the above, call Raritan tech support at 800-352-5630 x 6 and ask them to trouble shoot it.
I don't THINK the tank product had anything to do with it. Most tank products are intended to be flushed down the toilet...'cuz they may not make it to the tank if you put 'em down the deck pumpout fitting. However, I wouldn't leave any sitting in the bowl. That doesn't accomplish anything and can damage the joker valve.
