Used mast
279
Hunter 1980 37c Illinois
In the world I live in things have to be perfect replacements. When it comes to replacing my mast... simply where are the ditches dug on what to buy? Does it have to be nasa dead on exact?
Rick
Blaise
Hunter 37-cutter Bradenton
I had a friend replace a mast on his H37c after dismasting. It wasn't the same, and looked terrible. No it doesn't have to be the same, but it would be so much simpler if it was. Mast step would fit. Hole in the dect the right size. Rigging points in the same place, etc. I think the original Kenyon section is still available.
Sep 7, 2011
279
Blaise not sure what a kenyon section is. Guess I don't know much about masts.
Ed I need to go back and see what you were talking about.
All I have is this smartphone and it is tough to get around on.
Jun 2, 2004
5,802
The mast is just a big extruded aluminum tube. You can buy sections(lengths) of this tube. For the H37C you need a fifty-two foot section of #5280. Once you get onto that link you will see. It will be very expensive. Here is a link. Scroll down to "Mathurin2" and click on his name. Then send an e-mail or PM(private message) and ask him about the mast for sale.
http://forums.hunter.sailboatowners.com/showthread.php?t=134046
And remember that all you will be getting is the tube. Then there are winches and cleats and exit plates for halyards and tangs for stays and spreader brackets and . . . Be sure to ask Rig-Rite for a price on a complete mast.
542
Hunter 33 Seabrooke, Houston
RBLevens
I know there is a Hunter 36 or 37 in the yard I go to, as well as a few more smaller boats
Give Patrick a call at (281) 443-9898
Tell him you know me through this forum
Jun 21, 2007
2,118
Although from waterline mast height (from memory - I don't have the spec pdf with me) of the Cherubini 36 and Cherubini 37 are similar, the 36 is deck stepped, whereas the 37 mast extends down to the bilge. So the total length of the mast will very different.
Sep 10, 2009
194
Hunter cutter 37 1981 St-lambert
How it the world did you break your stick ? that mast is bomb proof thick ?
Jun 2, 2004
5,802
Geez, you are obviously right about the #5280! Sorry for the misinformation Rick. And I have the measurements right here in front of me, duh. Rick bought his H37C without a mast I believe.
Sep 7, 2011
279
It was broke in Katrina. I have the piece in the boat... I had a 22 foot piece that came with the boat... I cut it up I should be able to recycle it... pretty heavy :)
Blaise
One more thing, gents. The extrusion only comes in 25' sections and must be welded together. At least this was the case when I had to replace the bottom three feet of my mast.
Sep 10, 2009
194
Wow, really! There is no obvious joint in the 52 foot span of my mast.
I don't think the original mast was made out of 25 feet sections, it probably was made in one piece. Rigrite probably stores them in such length to save space.
