holding tank
704
Catalina 30 Sidney B.C.
I am going to install the waste holding tank in my 1982 Catalina 30 and was wondering who made the tanks back then
Oct 2, 2006
1,517
Jboat J24 commack
I went simple with the Sealand combo head / 9.5 gallon holding tank
It is S#$% simple and has had no smell issues after one full season and pumps out nice clean at the station
Dec 2, 1997
9,011
- - LIttle Rock
To answer your question...
Ronco Plastics Ronco Plastics has made water and waste for at least 20 years, so I'd bet at least $1 that they made yours. Give 'em a call to find out...if they did, they'll still have the mold and even know which one it is.
However, the SeaLand 711-M28 "Marine Traveler" that Tommays installed is a great self-contained system that uses the same bowl assembly as the VacuFlush, and uses pressurized flush water--but UNlike the Vacuflush--really DOES only need about a pint/flush...which allows that 9.5 gallon tank to hold at least as many flushes as a 30 gallon tank connected to any other toilet. If that's not enough capacity you can reroute the pumpout line to a second holding tank (you'd need a macerator pump). The only downside is the20 x20 tank footprint...it's too big to fit in most heads. Defender carries it for a very reasonable price: SeaLand Traveler at Defender
Jul 8, 2011
704
Hi Peggie due to the placement of the waste tank i am installing is it possible to plumb the outlet through a maserator to the kitchen sink drain or the engine raw water intake , making sure i install a valve to close off any access to sink drain or engine ...of course motor would not be running ...this would be temporary until next haulout or should i run maserator line to stern and install outlet just above water line with shutoff valve at exit at stern
Dec 2, 1997
9,011
- - LIttle Rock
Nope... do NONE of the above!
Nooo. CG regs prohibit a toilet or holding tank discharge line sharing a sink drain line, with or without any valves, even temporarily.
or should i run maserator line to stern and install outlet just above water line with shutoff valve at exit at stern?
Nope...not the right way to do it either. Install a new BELOW waterline thru-hull and seacock, fairly close the to the tank.
Where ARE you putting the tank? I think maybe you need a little help getting this right, so maybe we should talk? If so, send me an email (EMAIL plz, not a PM?)...I'll be glad to help you!
