Gel or AGM battery for my 309?
Catalina 309 Jacksonville, FL
I need to replace my 4D batteries on a 2008 309. I notice that a gel battery apparently has about three times the discharge/charge cycles as compared to the AGM type. But the AGM has about a third more cranking amps.
Does anybody have an opinion on my best replacement? I sail in warm weather (Florida) and am rarely more than two days from a shore power...mainly day sailing and weekend trips. I may eventually look at an air conditioner.
I appreciate your advice.
Feb 9, 2010
30
Undecided 30' Something Oyster Bay, NY
I'm sure everyone has an opinion but I do know that's it's not a good idea to mix battery types. I would think that if you're planning on adding an A/C, and running it away from the dock, you may want to look at a genset.
Mar 20, 2007
500
Catalina 355 Kilmarnock, VA
Any reason not to consider conventional flooded batteries? You might want to look into using 4 six volt golf cart batteries rather than the 2 4D's - much easier to heft in and out, and they're about the same size (though I'd measure carefully since the compartment barely accommodates the 4D's). I replaced my original batteries with AGM's due to lower maintenance and less self discharge over the winter, but will consider flooded batteries next time around.
Mar 20, 2007
500
Also, don't even consider trying to run an A/C off battery power. There are lots of discussions on this topic on this and other forums. You pretty much have to use a portable generator on a 309 when away from the dock.
11,724
If you have the height in your battery compartment for wet cell 6V that is an excellent option. Gel's generally do last longer than AGM, HOWEVER, they require absolute precision in charging and are the easiest batteries to ruin if you charge them poorly. While I have seen Gel batteries last for a long time it is always on a boat that is fastidiously maintained and owned by someone who has a deep understanding of the charging system.
AGM's in contrast I see last considerably less long than deep cycle wet cells. This is probably attributable to the fact that AGM's really like to be topped up to 100% full after each use. They also do not like to be trickle charged, Lifeline specifically states not to, so both mooring sailed boats and boats at docks that leave the charger on 24/7 can suffer shorter life.
As for cycle life we should remember that those are LABORATORY cycles not real world.... They do one after the other and the batteries never get a chance to sulfate like they do in a boat. Charging is also usually temp compensated in these lab tests.
If I had to guess at it I would bet that 99% of the sailboats out there never even see 1/3 of the claimed cycles of any battery, wet, gel or AGM, before they are dead. Heck Lifeline claims 1000 cycles at 50% depth of discharge and I have yet to have any customer that I know of break 300 cycles before their AGM's were dead. I'm sure you can find a few but I have not..
My customer a few weeks ago was under 100 cycles and his AGM's were flat dead at less than 4 years old.. Even if you do 50 cycles/overnights to 50% per year, which is a lot for most coastal boaters, that is still only 250 cycles over 5 years. The vast majority of batteries on boats don't last much more than 5 years, though some do and I do have customers with 6-11 years on banks but these boats are all cycled rather lightly to perhaps 70-80% state of charge as the lowest depth and all are deep cycle wet cells including very heavy duty brands like Rolls..
Just looking at the calendar for this season we have approx 54 nights, I may be wrong on some weekends whether they were two or three nights, and we often take 3 day weekends as my wife does not work Mondays. I suspect this is more than most coastal boaters do in an average year? One of our friends only got 15 nights this year and on a good year they might do 20 nights on the hook. At that rate, based on Lifeline's "lab testing" for cycles, their batteries should be lasting 50 years....:D:D
Ignore "claimed" cycle life and buy the thickest plate batteries you can fit. 6V are always thicker than 12V.
CCHer
Jul 7, 2010
230
Beneteau 37 Cranes Creek, VA
David, I just replaced the 7 year old OEM 4Ds on my 310 this past weekend with 4 232AH 6 volts-Interstate golf cart. They are 3/4 inch taller, two of them together lengthwise about an inch and a half longer and a little narrower. They fit okay in the 310 though I had to reconfigure the hold downs. I have a lot more AHs at half or a third the cost of gels and a lot easier to handle. The little extra time to monitor the water levels from time to time is no big deal given the cost difference IMO and you get the bonus of more AHs in the footprint. As Maine Sail says they are probably more forgiving with the way we use them on boats as long as the fluid is watched based on what I've read during my research for replacement batteries.
Hunter 27_75-84 Frankfort IL
Replacement battery for 4D
I just went thru this and opted to replace my 4D with 2 Group 27s wired in parallel. On the advice of a longtime sailor friend I have used the Delco Voyager batteries on my boats for several years with good success. While they are not "maintenance-free", they are sealed and do have a built-in hydrometer (red/green indicator) and I have never had a problem. I replaced my starting battery with one 3 years ago, and when my 4D went bad last year I wanted something close to the 27 Delco. Of course they had nothing in a 4D, so my choice was stick with a wet-cell, or convert both to AGM, at a significant cost. I had toyed with the idea of putting 2 27's in parallel and when I asked a good friend who has cruised in a a Cat 34 for many years, he told me that is the configuration that he has and it works well. I found that if you buy 3 Group 27 /30 plastic batttery boxes and cut off the handles on the sides, they fit perfectly in the 309 battery compartment.
