The water was like glass for the most part. For a good amount of the time, there was so little wind the wind indicator didn't register. At times, the sails hung loose. I wanted more wind but that's what I was given. Also, the new telltails I put on the main sail were stuck to the sail by static.
I had read Don's book so I let the halyard loose to move the draft back and tightened the outhaul and vang. Those are pretty much the only controls I have. No movable fairleads for the jib. I managed to make enough way with only a 100% jib to be able to tack. When I turned to come in and had the wind behind me, I loosened the vang and outhaul.
I hope I'm learning.
Those were difficult conditions. At times I couldn't tell what direction the small amount of wind was coming from. It wasn't enough to feel on my face or move the tell tails even (the ones which weren't stuck to the sail).
I'm not sure if I got to see the differences of good trim vs bad. Maybe this weekend will be better.
