I was doing some maintenance today (gale-force winds from the north and heavy seas kept me from venturing out on Lake Michigan:cry
Was checking on the batteries and found both of them had come unstrapped, and one of them was on it's side. There was some liquid under the battery, so I carefully sopped it up after restrapping both batteries in place.
Checked the bilge and it also had a yellow-ish liquid. Seemed like way too much to come from the battery, but when I tried to use the bilge pump, the liquid seemed to foam. So I soaked as much as I could up with a sponge and then flushed the bilge with water a few times.
Is there anything else I should do?
The battery that had tipped over was pretty much lying on my speed transducer...I wonder if that explains why the speed indicator seemed to be about a knot slow on the last sail?
