I am so darn happy I could pass out!
RECESS
Dec 20, 2003
1,509
Catalina 27 . St. Mary's Georgia
My 9.8 hp Tohatsu 4 stroke with the 25" ultra long shaft showed up today. She feels sooo shiny! I set her next to my 2.5 hp Yamaha 4 stroke. I am doing everything I can to keep Japan's economy afloat!
breath...breath.....breath
Sumner
Jan 31, 2009
5,254
You will like that outboard, we sure do. We also then bought a 3 1/2 HP long shaft Tohatsu for the dinghy and so far love that outboard also.
The elect. start on the big one sure is nice and a big safety factor also. I switch out the 5 pitch 4 blade that came with it for a 7 pitch 4 blade since our boat is probably only 3500#-3800#. The part number on the 7 pitch if you are interested is 3B2B645120
http://www.tohatsuoutboardparts.com/Props-and-Hardware.html#Aluminum
After 3 months in Florida with it and over 300 miles on the outboard we like the 7 pitch, but to be honest never tried the 5 pitch. I think it would be great on a boat over 5000# to 6000#. The 7 has a lot of thrust in forward and reverse and I wanted a spare prop anyway so still carry the 5 pitch. I also bought an extra properller hardware kit, 3V1-87326-0, just in case I had to change a prop on the water and something went to the bottom.
I don't know if any of this will help, but it is easy to put a higher, longer tiller handle on it....
http://purplesagetradingpost.com/sumner/macgregor2/outside-26.html
...... and extend the throttle....
http://purplesagetradingpost.com/sumner/macgregor2/outside-27.html
...and gearshift...
http://purplesagetradingpost.com/sumner/macgregor2/outside-28.html
.... plus I put a quick on-off connector between the rudder tiller and the outboard tiller....
http://purplesagetradingpost.com/sumner/macgregor2/outside-29.html
Have fun with it,
Sum
Our Endeavour 37
Our MacGregor S Pages
Mac-Venture Links
RECESS
Dec 20, 2003
1,509
Very good info Sumner. I think it is a very safe bet that my metal fab skills are far below yours.
May 23, 2007
1,306
Catalina Capri 22 Albany, Oregon
Hey Sumner, do you know if those props will fit a 2008 Merc 4 cycle? Mercury apparently doesn't make extra props for the 4 HP anymore. I've been thinking the high thrust might get me to hull speed without being wide open.
Sumner
Jan 31, 2009
5,254
I'd call onlineoutboards and ask them if this one would work:
......dia.........pitch.....blades..................................Tohatsu Part Number
......8.375 ....... 6 ......... 3
(high thrust) (6hp SailPro model) 399B645121
I know you probably know that Tohatsu makes the small Mercury outboards, but I think there are a few differences. The 4,5 and 6 HP are all the same outboard, just a different carb.
They are who we got our Tohatsu outboards from.
If you don't have luck there I know of a place that might be able to re-pitch the prop. I had a prop for our Honda 8 HP re-pitch. If I remeber right it was about $100 total for the prop and to have it pitched to a lower pitch. They did a nice job. I can't remember the name of the place off hand, but it is in our records,
Sum
Our Endeavour 37
Mac-Venture Links
Dec 2, 1999
15,184
Be sure to run the fuel out of the hose & engine after each use. The new fuel is crap and can screw up a motor.
Fuel stabilizer is also not a bad idea.
