Bowl Fills
gpd955
Feb 22, 2006
1,164
Catalina 310 Cape May, NJ
Hi Peggie:
Got to the boat yesterday and found that after 3 days away the bowl of my Wilcox Crittenden electric flushing head had some (maybe a cup or two) liquid waste in it. Thinking that maybe my 7yo snuck in after I cleaned up the other day, I wrote it off and flushed it away.
Woke up this AM after about 6 hours, and same deal.
Head was pumped out last Saturday and we were only on the boat for 1 day after that and prior to our return, so the tank has very little in it. I will be heading out this AM and plan on pumping out again just as a precaution.
Is this a typical symptom of a joker valve problem? Any diagnosis?
WayneH
Tartan 37 287 Pensacola, FL
It sounds like you're getting backflow from your joker valve. It's probably everything up to the top of the vented loop that is returning to the bowl.
Dec 2, 1997
9,010
- - LIttle Rock
Need more info
It's unlikely that what you're seeing is runback from the vented loop if there's no vented loop in the discharge line. But if it's an uphill run to the tank, it still could be runback of waste left sitting in the line. So...describe the head discharge line route to the tank.
How old is the joker valve? It should be replaced at LEAST every other year...annually better. If it's any older, it's allowing backflow to come back into the bowl.
But even a brand new joker valve won't stop slow seepage...so if this a new symptom, it could mean that a blocked tank vent has pressurized the system, creating back pressure that's not allowing waste to make it all the way to tank. If your tank vent's through a slit in the rail stanchion, a blockage is HIGHLY likely. That's something only Catalina does that should be corrected...meanwhile, scrape out the slit with a screwdriver blade. Check it on an almost daily basis to keep it open.
Or, if your toilet uses sea water, sea water mineral buildup in the head discharge line may have reduced it enough to create back pressure creating run back.
Either way, if if is WASTE in the line, not clean flush water, says that you're not flushing long enough to move bowl contents all the way to the tank and/or not rinsing out the system before the boat will sit.
Or, if your toilet uses raw water AND you don't bother to close the intake seacock when you leave the boat, it may be that the solenoid valve in the intake vented loop has failed...that what you're seeing isn't waste but dirty marina water from the intake. Or, if there is no vented loop in the intake, the intake pump is leaking sea water.
Start by replacing the joker valve. And while you have the discharge fitting off and the joker valve out, take a good look at the inside of the discharge hose to check for mineral buildup. Check the tank vent...and if it's been at least 5 years since the toilet was rebuilt, it's time to do it again...while you can still get the kit from Thetford. Thetford discontinued the whole W-C line at the end of '09 (or maybe '08...I lose track of time)...rebuild kits are about the only parts left for any W-C toilets.
And btw...you pumped out the TANK, not the head.
Dec 2, 1997
9,010
- - LIttle Rock
Electric toilets and joker valves
The vented loop in the intake line for an electric toilet has a solenoid valve that's connected to the flush button Pushing the flush button closes the air valve so that the pump can prime, releasing the flush button opens it again to break the siphon
You said, " I strongly disagree with this idea of rebuilding toilets on some schedule, replacing parts on some schedule - like replacing a joker valve "at least every other year" - which implies preferably annually. This is a waste of time and money."
I hope you don't apply the same thinking to the preventive maintenance for the engines in your boat and vehicles! Unlike household toilets, marine toilets have moving parts that require PREVENTIVE maintenance. It's called "preventive" maintenance because it PREVENTS problems that have to be fixed. You get to do PREVENTIVE maintenance on YOUR terms, when it's convenient for YOU...unlike repairs, which NEVER are needed at a convenient time.
Since you're unaware of electric solenoid valves in vented loops, you've only had manual toilets...and it's time you learned how a manual toilet works:
JOKER VALVE 101
Most people think that the only thing the joker valve does is acts as a check valve to stop backflow from returning to the toilet or odor from the tank from escaping through the toilet. But that's not a joker valve's most important function...in fact, the joker valve is THE single most important replaceable part in a manual toilet. Have you even bothered to LOOK at yours in the last 10 years??
Here’s how the discharge half of the pump works: On the upstroke of the piston, a vacuum is created in the area beneath the piston. This causes the joker valve to close tightly, and the flapper valve beneath the pump to open, allowing some of the contents of the toilet bowl to be drawn into the bottom half of the pump. Then, on the down stroke of the piston, the flapper valve is slammed shut, and the effluent is forced out of the bottom of the pump, through the joker valve, and off down the line. But when the joker valve becomes worn and/or there's a buildup of sea water minerals on it, it can no longer seal tightly on the upstroke of the piston...less vacuum is generated when you pump it. And as it becomes more worn--as the slit gradually becomes just an open hole, creating less and less vacuum--finally the bowl contents simply move up and down a bit, but don't go anywhere. Sometimes the flapper valve needs to be replaced too, which is why toilets should also be rebuilt at least every 5-6 years as PREVENTIVE MAINTENANCE.
You prob'ly won't notice the loss of efficiency at first because it's so gradual...same as we don't see that we've gotten a little older than we were yesterday when we look in the mirror each morning. But I guarantee you that if it's been more than a couple of years since you replaced the joker valve, you need to pump the toilet at least 50% more times to move the bowl contents to the tank...or, they just aren't getting there any more.
You said, "The best way to keep a marine head working is to flush with lots of water when you use it."
Really?? You must have VERY large holding tank, or you don't bother to use it. Because the right way to keep a marine toilet working to spec is by keeping the pump well lubricated and by doing preventive maintenance on schedule. When a toilet is working anywhere NEAR specs, it can move bowl contents at least 6 linear feet and up to 4 vertical feet in the dry mode...more than far enough clear the top of any vented loop. Maintaining your toilet and learning to use the dry mode to do more than just empty the last of the water out of the bowl can double the number of flushes your tank can hold.
You also said, "On the other hand, if your system is plumbed to that it's uphill to the holding tank, then it's just designed wrong."
Really??? Please tell where to put a vented loop that isn't uphill from the toilet. However, even without a vented loop in the system almost all tanks on sailboats are at least slightly higher than the toilet discharge. The bilges aren't deep enough to put them below it.
However, it's obvious from the tone of your post that your approach to maintenance is "only fix what breaks" and nothing I say will convince you that preventive maintenance keeps things working better longer and costs less in the long run. But it's your boat...whatever floats it for you is fine with me.
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
redacted
I deleted my replies here, because this is an inhospitable forum. I will stick to those forums that appreciate differing views and good natured, spirited discussion.
LuzSD
Feb 21, 2009
1,009
Catalina 30 San Diego/ Dana Point, Ca.
picking up your marbles....
gosh Jviss, though I thought both of you were a bit fiesty, I think Peggy was answering you in the same tone you had and it was a good spirited discussion. I was about to ask you about what type head you had...
don't pick up your marbles and go to another game, then you are doing exactly what you said you did not like! come on, put your posts back so this conversation makes some sense to those who are interested. :confused:
Oct 3, 2008
325
Beneteau 393 Chesapeake Bay
That's too bad because Peggy gave you some very good advice. I have read her book and most of her posts and have found them very useful.
Alan
Jun 2, 2004
4,174
Hunter 35.5 LI, NY
Some folks will tiptoe around with their thoughts and ideas, others are a bit more demonstrative. Peggie has never been one to allow anyone make a statement that she knows is wrong and not correct it. Some of the things that you stated are clearly wrong and she made 'no bones' about pointing out your errors. If you took her response to be "inhospitable" then you just don't 'know' Peggie too well yet. I've been around this forum for a good many years and I too have been put in my place by the head mistress when needed.
It would be a shame for you to up anchor and sail off due to difference in personality. Our country has become grossly fractured lately to the detriment of all of us. A way back to the center is in order. Please re-consider your decision and know that you are one part of the whole and widely differing group that we are.
gpd955
Feb 22, 2006
1,164
FWIW I took jviss' advice (started with the easiest solution) and it has seemed to work. Woke up today with no backfill. So if you read this jviss, thanks.
I always take Peggie's advice too, as she has never steered me wrong, so since I have no idea when the valve was replaced, or anything else(impeller, cutter, etc.) in the toilet for that matter, I am going to get a maintenance kit and just do everything when I get an opportunity.
I appreciate EVERYONE'S advice and opinions in the forums. Unfortunately sometimes "text" does not reflect "presentation" and it leads to this kind of stuff. I know I have a tendency to try to make things humorous when I post and reply...sometimes without success...and have PM'd people to make sure I didn't come off in an unintended way. That's just me though!!
Again, thanks everyone! Oh, what's a good lubrication for the head?
Dec 2, 1997
9,010
- - LIttle Rock
Electric toilets don't really need lubrication
It's MANUAL toilets that need to be kept lubricated 'cuz they have wearable rubber valves, seals and o-rings that are subjected to constant friction against the inside of the pump cylinder.
But electric toiles don't need lubrication 'c uz the only moving parts are the motor--which is sealed so you can't lubricate it, a metal cutting blade that doesn't need any...and two impellers--intake (except for the Raritan SeaEra which has a diaphragm intake pump) and discharge. So there's really nothing TO lubricate. Just make sure that the toilet never runs dry, 'cuz dry friction heat "fries" impellers. Which is what makes it a VERY bad idea to keep the intake seacock closed and add water to the bowl from the sink or shower head.
gpd955
Feb 22, 2006
1,164
Well it's good to know that I have not been lax in my doody....I mean duty...to lube the toilet! I had used mineral oil ( and sometimes a few drops of dish soap in a pinch) in the manual in the old boat.
Dec 2, 1997
9,010
- - LIttle Rock
I'd love to have that photo for my files! If you still have the original high res, it could (with your permission of course) even end up in the revised edition of my book!
