Hi All,
I recently purchased a '79 30ft Hunter from my grandfather who no longer has the capacity to sail. I have experience with boats in general but limited sailing knowledge - I have been trying to bring myself up to speed with multiple resources.
I have a laundry list of projects, but currently working to replace the original stereo head unit which is dead. I was looking at two different options - either running a new head unit and installing two 6.5 speakers, or using a powered "boombox" like the altec lansing linked here http://www.alteclansing.com/ae/us/i...imt810/&bklist=icat,3,shop,ipodiphonespeakers.
After pulling out the corroded existing head unit, I realized that rewiring the new head unit may be a bit over my head. The altec lansing boombox sounds great and is a simple solution.
I wanted to see if there is any drawback to using the boombox which is just plugged into an outlet. I have been trying to get a grasp on AC vs DC and the impact on battery draw. The boat runs off shore power in the harbor, but I am wondering if the power drain will be an issue away from the dock.
Lastly, if I go the head unit route, I would have to run power off of the boat batteries to power the unit on rather than just running AC and outlet power off the shore, correct? Supposing i have the battery charger switched on, this shouldn't be an issue correct?
Apologies for my ignorance, any help would be greatly appreciated.
