My 2008 Catalina 309 seems to have a water heater problem. When the engine has been running a while, my hot water from the water heater becomes overly hot--in fact, scalding. (I do not turn on the "water heater" fuse switch in the electrical panel, so the heat is from the engine heat exchanger, so I believe). To keep the water heater relief valve from sending hot water into the bilge area, I have to drain the water heater into the galley sink by running the hot water through the faucet for several minutes.
Has anybody else had this problem? Do you have suggestions? I have flushed my engine coolant system--this did not change the problem. My engine is not overheating according to my instrument gage on the binnacle.
David
David
