We are finally done with modifying the alternator setup on Mathurin II
. To make a long story short, we've had problem after problem during our 9 months trip because of a bad alternator installation. The prior owner installed a 120amps Balmar alternator in the original configuration on our 3qm30. Well that wasn's such a good idea. A 120amps alternator need at least one 1/2'' belt to run properly, preferably two (but not necessary).
The problem is that the stock crankshaft pulley on the 3qm30 is designed for one 3/8'' wide belt. So when we left Montreal, we slowly realized that the belts where slipping, so to avoid slipping we had to put more tension on the belts, thus more tension on the water pump... To resume the situation, we went through 14 belts and 3 water pump bearings in 9 months (950 engine hours). That's 290$ !!!!
That is already impressive, but to top it off, 3 days prior to our arrival at our home port, the alternator got loose and the 3 bolts holding it in place broke, we had to do the last 3 days with a belt mockup to run the water pump (god you love to have a Power-Twist V-belt on board these days) and the generator on deck. Had we known all of that before leaving, we would have put a 55amps alternator back in it's righteous place.
Now that we are back (with 3 broken bolts in the engine) we decided to address the problem once and for all. This meant custom dual sheave pulley on the front pto, custom off engine alternator bracket, new dual sheave pulley for the alternator and custom water pump bracket (the water pump needs to have some sort of adjustment now that it's running with it's own belt).
I designed the new pulley to fit on the pto using the specs found in the original service manual (Thanks again Jose). The drawing is included in this post. That pulley was machined by a local machinist for almost nothing (95$ including material). I found a brand new dual sheave pulley for the alternator for 30$ (Ford F1HU10A352AB) in a local alternator refurbishing shop, which is a lot cheaper than the 120$ retail price Balmar displays on it's website. The bracket where done using scrap metal.
The picture were taken before the water pump bracket was installed. You can see the red Power-Twist V-belt still in place. You can also see why it's a bad idea to paint when it's 100F outside, the alternator bracket will need to be repainted.
