36' Islander $9600 - A Good Buy??
marl
Jul 18, 2011
3
Hunter 310 Titusville, FL
Hi:
I found a 1984 36' Islander in Ft. Lauderdale for $9,600.00.
The problem is the hull smashed against the rocks and it's got a 2 1/2 ' X 12" gash in the side. It's been repaired but poorly and it's leaking.
He says everything else is in tact, including a 50HP diesel motor.
How much work/expertise would it take to fix a gash like that?
Can a gash like that be fixed to full restoration?
Can the boat ever be worth what it would have been if not for the gash in the hull?
Oct 2, 2006
1,517
Jboat J24 commack
Kind of depend on how Bad the rest is as making mine look good was the least of the issues :eek:
My sails and winches were only a few year old for example and had they been used up it would have really put a damper on the total cost
11,772
Hi:
Anything can be repaired $$$$$$ but it will no longer be a "good buy"... In almost all cases you are far better off to buy a boat that the PO has already done nearly everything to because you will nearly always pay a lot less that way than doing these things yourself......
marl
Jul 18, 2011
3
Wow, nice! How long did this take and @ about what cost?
May 11, 2005
3,431
Seidelman S37 Slidell, La.
Kind of depends
Two primary things. First, are you capable of doing the needed work yourself? Second, do you have the time, and do you enjoy the work? My suggestion would be that if the answer to either or both is no, then find yourself a boat that doesn't need much work. For some doing the repairs is as enjoyable as the finished product. For others just a major chore, that if not being enjoyed, may not get completed at all.
Jun 3, 2004
298
'79 Hunter 33' HUN33190M79L Olympia
I'm going to give you a different, but just as true answer as the rest have: It could be a very good deal.
All esle being equal (fixit qualifications, interest, experience) it seems to kinda depend on how soon you want to go sailing. :)
Oct 2, 2006
1,517
Jboat J24 commack
It took a bit over 1.5 years BUT now i have a boat i like with 2011 systems and rigging
Sep 6, 2010
61
w.d.schock santana27 San Leon,Tx
is a 36' islander worth fixing ?
i hear they dont sail well and are a little heavy
zeehag
Mar 26, 2009
3,198
36 islanders are good boats for cruising.
Not true at all.
The I36 skippers here on SF Bay have made a miraculous comeback, and in the past few years many, many more have been retrofitted, upgraded and brought back.
They are handsome boats and sail very, very well.
Even with the pinched stern, their belowdecks accommodations were well ahead of their time.
They race a lot here as a one design, and maybe some PHRFs, too.
Nice boats.
Ross
Jun 15, 2004
14,693
I have an Islander 30 and I am very pleased with it. I have spent far more money than I will ever recover but I have a boat that I know every square inch of inside and outside. You must be a competent craftsman to make the repairs and to install all of the systems needed to make the boat meet your standards. If you don't have the skills or the determination to stay with the entire job then don't start. Buy many books and read many more. expect to spend a couple of thousand dollars for tools, portable and stationary. My boat came with sails and spars but needed new standing and running rigging, a new engine and all that is involved with that. A new toilet and holding tank, a new galley.
Would I do it again? Damn right because I thoroughly enjoyed making a boat that is uniquely ours. There is no other boat anywhere that is the same as ours. We don't use it as much as we would like but who in their right mind goes sailing when the temperature is in the low hundreds and there is little to no wind?
Catalina 320 Dana Point
"Anything can be repaired $$$$$$ but it will no longer be a "good buy"... In almost all cases you are far better off to buy a boat that the PO has already done nearly everything to because you will nearly always pay a lot less that way than doing these things yourself......"
Nice try Main, very good answer.
"You want the truth? You can't handle the truth!" Jack Nicholson
zeehag
Mar 26, 2009
3,198
boat was designed by either alan gurney or bob perry-is a good sailing boat and capable of long voyages in fairly decent comfort for a perfomance cruiser. cool looking and practical. if you want to do the work, you WILL have a good boat capable of going anywhere you wish to go .
Ross
Jun 15, 2004
14,693
You can find many very good books on sailboat remodeling.
The work that Charlie Cobra does on wooden boats and for which he is applauded , is scorned for fiberglass boats.
That makes little sense to me.
As investments a boat is probably the worst investment after a racehorse. We don't own them because we can get a good return on our money.
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
Any more info?
Where the gash is and how the boat is constructed makes a big difference on how repairable it is. If the boat was built with a structural grid and there was damage to the grid it will be a lot harder to fix than a boat with a tabbed in interior. Repaired poorly? So now you have to go in and fix what someone else has screwed up already? :doh:
Ross
Jun 15, 2004
14,693
This is a good way of saying that you can't get dollar value for the new materials put into a boat to say nothing of recovering the value of your labor. Buying an almost finished restoration boat can be a very good value if it gets you the boat you want.
11,772
Exactly! Case in point a neighbor was looking at two Catalina 30's one in top notch condition needing nothing but your own fresh linens and the other needing nearly everything. Both boats were the same year, same model and only 8k apart in price with the most expensive being about 32k. Well three years later, a re-power, new standing & running rigging, new canvas, new sails, deck core repairs, wiring upgrades, batteries, interior cushions etc. etc. etc. he had over 60k into a boat still worth 28-30k.... For 8k the other boat was already there.....
Ross
Jun 15, 2004
14,693
The one needing restoration was really worth about $4000. Because when it was finished it would have all new systems.
