PO put an inspection port in my bow deck so I can get to that stuff pretty easy. Still not looking forward to re bedding the stemhead bolts or anything else up there. It's tight!
I had to take part of the rub rail loose where it goes around the bow which meant removing the rubber from the Starboard side all the way around the bow to about four feet of the Port bow to get the old stem chain plate out. Because of the angle of the chainplate, you're not going to be able stick all the bolts into it as Main Sail has demonstrated in his thread on bedding deck hardware.
I had to remove the small bulkhead in my bow in order to get at the bolts to thread the nuts and washers and it's still a son of a gun trying to do that with a ratchet and extension w/socket but it's doable with patience.
I cleaned up the area under the gunwale molding and used a dab of left over BoatLife Boat Caulk on every screw head and screwed the molding right back on. I cleaned and let the rubber soak in a bucket of warm soapy water and stuck it back into the molding.
After that project was complete, it was on to the next project.
I had to cut 2 inches off the bottom of my mast. Back in the mid 1990s when I had Rig-Rite set up my new Z Spar mast with a Kenyon stainless steel mast Tabernacle and utility plate, they made up a mast plug out of stainless steel which caused the bottom of my mast to corrode. Two years ago I was able to have my mast welded but this year it was terminal again. I had my son come down with his cross cut saw with a carbide tip blade, cut my mast. I gave the two inch piece of my Z-190 mast to Rudy so that he can have some mast plugs made up. Hopefully I'll be able to buy one off him and stick it on my mast. I had to put the same mast plug back in and I made up the 2" difference with two pieces of Trex. I cut up a one gallon plastic milk container to use as a separator between the stainless steel and the Aluminum.
I replaced the 1" Teak under my mast step with a piece of 12"X5" piece of Trex and caulked it with Butyl Tape. This will be permanent on my boat. The mast plug and the Trex is temporary until I can get an Aluminum mast plug made up and figure out what to use for a 2 1/4" spacer. It looks kind of fugly, but it works. Talk about fugly,--check out these two guys.
