Whistling rigging
492
Oday 222 Mt. Pleasant, SC
I haven't had my boat out for a sail yet so I know there are tweaks to be made to the rigging still. I was just wondering what causes the rigging to whistle in the wind. I tightened things up a bit more since I heard it last but haven't been when there is wind to see if it's still whistling. Do some rigs just whistle when the wind hits it right even if things are tuned correctly?
Jeff
Sep 29, 2008
195
Hunter 33.5 Carlyle Lake in Central Illinois
Enjoy what we call harbor music. Between the whistling rigging and the slapping halyards is gets pretty noisy around our harbor when the wind picks up. I've noticed
we get a droning sound from our topping lift when the main sheet is too tight. As
soon as I loosen up the main sheet it quits.
Oct 10, 2006
492
I like the sound, even my wife commented how nice it sounded. The problem is my boat is docked at my in-laws house. The dock is separated by about 400' of marsh from the house and you can hear it from the pool. Again, we all like the sound, but the neighbors across the creek are only about 50-75' from the boat. I've got the halyards squared away so they don't slap so at least I'm not "that guy"
gpd955
Feb 22, 2006
1,164
Catalina 310 Cape May, NJ
Our marina rules force us to secure halyards, so we don't get much slapping. I secure mine anyway to avoid that amplified noise down below. They do sound great, though, when topsides. Something comforting about it.
The other great marina sound is the howling in our neighbors mast with the in-mast furling. You know when you hear it you're getting a nice NE sea breeze and it's going to be a comfortable night.
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
A round wire is one of the least aerodynamic shapes causing an incredible amount of drag due to separation of the airstream as it passes over the wire. High tech boats use foil shapes for their rigging to reduce this drag. Along with drag comes acoustic noise. Either the rig itself vibrating like a guitar string or from the airstream acting like a whistle as it passes over the wire. Loosening or tightening the rigging should be based on proper rig tuning, not on the frequency of the vibration from the wind. Changing the tension in the wire will change the vibration frequency thus changing the tone of the note being played but won't effect whether there is a note or not by much. You might try putting something on the wire to dampen the vibration, maybe a foam sleeve like those noodle things for swimming pools just to see if it makes a difference.
zeehag
Mar 26, 2009
3,198
slapping hayards are obnoxious and curable. there is no reason to allow halyards to flog/slap/be noisey. when halyards slap the mast they are making damage to both halyard and mast.
singing rig is not curable--wind speed causes the different tones and tunes heard when wind is blowing thru them at different speeds. have fun..
May 23, 2007
1,306
Catalina Capri 22 Albany, Oregon
My halyards don't slap and my rigging doesn't sing, but those ©@&@ little metal turnbuckle covers are driving me nuts! Every time the burgee or boom tent line slaps the shrouds they rattle. Next season they're gone.
Jun 6, 2006
6,990
The totally deranged would wrap the shrouds in a thin layer of yarn. All those little fibers tend to hold onto the air right next to them (like a beavers fur) and keep the shroud quiet. Google "boundry layer" You could get creative and use different bright colors to add a festive mood to the boat.
Jul 28, 2010
914
Boston Whaler Montauk New Orleans
I guess there's slapping and there's slapping. But basically, I've had some of my most peaceful sleeps on a sailboat listening to the slapping and the whistling, even in crowded marinas. It's comforting to me. Everything's right with the world.
Plus, I can consciously or subconsciously hear changes, and if it's a "bad" change, I'm on it.
Oct 10, 2006
492
That should work because I've never heard a beaver whistle when the wind is blowing through its fur
zeehag
Mar 26, 2009
3,198
fouling the halyards around the spreaders/shrouds keeps them intact and noise down-- wont have to replace the halyards as often as when they are allowed to keep others awake all night with each wind change. neither of my boats have slapping or flogging halyards. takes only one flip for htat protection. i hear the singing at more than 15kts of breezes. by 100 the winds are howling so hard my rig isnt even noticeable.
Aug 2, 2005
374
pearson ariel grand rapids
Expanding this, and a more practical approach is to wind a single strand of yarn or wire along the length. Widely spaced wraps work fine, something like one wrap every three inches or so. It breaks up the air flow and stabilizes the wire so it doesn't make noise.
Same concept is used on modern car antenna
gpd955
Feb 22, 2006
1,164
I have a shroud cleat on port and starboard and attach my spin and main halyards to that. Works great. Last boat I bought a bag of the thin bungee cords and used them to pull the halyards away from the mast. As they would wear down, I'd just pull another out of the bag....and I would also donate some to those who didn't take car of thiers.
WayneH
Tartan 37 287 Pensacola, FL
Speaking of whistling, my neighbor's horseshoe float starts whistling on a southeast breeze at 15 knots. :)
Wayne, here's an idea: suggest to your dockmate that his float will last a LOT longer if he stores it down below!
We used to go through those once every five years until the light bulb hit us on the head!
He can store it in his head, too... :):):)
Feb 1, 2011
21
Sabre 426 Liberty Landing Marina
Some rigs do..it depends on your set-up..are you a roller furling? If it's more of a humming you might want to try loosening your topping lift and you can decrease your back stay if you have one...good luck!
Oct 10, 2006
492
No roller furling and the boom wasn't installed at the time. Like I said, since I haven't had it out for a sail, I haven't tuned the rigging yet so everything is just hand tight and all pretty even all the way around the boat.
