I need to replace the throttle cable on our '84 Hunter 31. Do I need to drop the pan in the aft quater birth to do this? Are there any tricks that will make the job easier? Any help would be great. Bert
You will need to drop the pan. There is also a screw that holds a bracket that secures the cable to the pedestal housing. You will need to loosen this screw to remove the cable and then you need to get the new cable secured again upon replacement.
Best of luck, this is not a job for the faint of heart! You just need patience.
