3QM30F Raw Water Pump
63
Hunter 37 C Long Pond, NL
Hi Everyone
I need to repair the raw water pump on my 3QM30F. I think the pump is driven off the cam shaft.The shaft is scored and needs to be replaced. My local Yanmar dealer says the shaft is no longer available. Is this pump actually a Yanmar pump? Is there a bolt on replacement? Any suggestion would be helpful.
Thanks
Sailor jack
S/V Slainte
1983 H37C
Sep 30, 2010
130
hunter 33 Hunter Morehead city
water pump
Jack, this can be used to fix the scored seal surface of the shaft:
http://www.vsm.skf.com/en-US/HeavyDuty/KitsAndTools/SpeediSleeve.aspx
If the bearing fits are bad, a good machine shop can make a new shaft out of stainless for not much money.. The bearings and seals are available from Yanmar at very reasonable prices.. I just rebuilt that same pump for a buddy's 2QM20..
Jack I have a complete pump for sale for 250.00 if you are interested, It is in excellent condition. You can email me at bugaloo28557@yahoo.com Robert
Sep 10, 2009
194
Hunter cutter 37 1981 St-lambert
Have you openned the pump ? If it's the same one than on our 3QM30 then it must be a Jabsco 2760-0001 or 2760-0003... (http://www.pumpagents.com/pdf/JabscoPumps/2760-0001.pdf)
If it's leaking from the holes around the pump, it's propably two things (and probably both). The inner seal (part #14 on the .pdf above) must be dried and cracked and the bearing (item # 11) must be blown due to too much tension. The bearing is the weak part on this pump (we used to change it every 350 hours because we were putting too much tension on it). You can buy the bearing in any locale bearing store for around 45$ (FAG 3200-B-TVH if I recall correctly, many interchange). For the inner seal, you need to buy it from Jabsco, that seal was made to their specs, it's worth around 15$. You can use a big c-clamp and a socket if you don't have a bearing press. Read the ''Assembly'' section in the .pdf if you want to know how to take it apart.
If it's leaking, don't take any chance, the bearing will likely explode within the next 25-50 hours...
Sep 10, 2009
194
Oups, misread, if it's the water pump on the engine, than it was originally made by Johnson... the impellers are no longer availible from johnson so I'm not sure they still carry spare parts for the pump...
Jun 2, 2004
5,802
Right you are Maturin. He's talking about the raw water pump, middle left in picture. You can't see it but that's a new Jabsco behind the pulley on lower right. That's the 2QM20 that I replaced with the 3YM30. Great engine in a lighter boat.
130
Raw water pump
I think the pump he is looking for is a double impeller pump that bolts on the front of the engine and is driven by the cam shaft and not by an engine pulley. Robert
May 2, 2011
63
Thanks everyone for the help. I will let you know how the repair goes. Unfortunately work is getting in the way of sailing.
Nov 22, 2008
22
84 Hunter 37c bradenton
Jack, our local Yanmar dist. {Mastry Engine Center} listed this shaft as still available. Part no.124770-42030. This number superseded all others. He has them in stock.
