Here is what I know:
- Engine runs very well with ample power at all rpms
- I have to top off the overflow tank after every 4 hours of motoring
- No overheating(yet)
- No coolant in oil(crack in block)
- No pressure in heat exchanger when running the engine with the cap removed(bad head gasket)
- No apparent leaks under engine
What is left are the following:
- Hot water heater leak
- Heat Exchanger leak
- Exhaust riser leak
- Hidden engine leak
- Something I am missing?
Any of these should have coolant in the bilge, hot water system or the exhaust. Does anyone know of a way to test for coolant(trace amounts) in water?
