I bought Lewmar 30 STs to mount closer to the helm position to make single-handing easier. To get the proper 5-10 degrees angle leading up to the winches, I either need to mount a leading block from the toerail or a stanchion base. I've searched the archives, but can't seem to find out how the hull/deck joint is constructed. I can't get at the backing because of a hard headliner. I don't think a stanchion would take the high forces a 135% genoa would load it with, and since I can't get to the back of the joint to use reinforcing plated below the deck, I'm stumped. There is room to reach the area under the coaming to use reinforcing plates under the winch. Any suggestions? Thanks.
