Looking for other Hunter 270 owners that have tiller/outboard. I have only seen diesel/wheel 270 models advertised for sale. My 2002 270 also came with a 165% Genoa.
I have the boat launched by crane every Spring. With 3.5 feet of draft it could be trqiler launched but that would be difficult.Question: How hard is it to launch with your 3 foot draft?
I have a 260 and seen a 270 for sale. Launching single handed concerned me.
Can you launch from trailer ramps or do you have to sling every time.
Mark
Vancouver
Um...seems you have a unique boat. I, too, was under the impression that a 270 was just a fixed keel, inboard 260. So having a fixed keel with a tiller and an outboard, that is a unique animal indeed.
I think the forum might be interested in your opinion on how the boat sails. While a water ballast boat is tender, our 260 is a very easy boat to balance the sail plan and is a pleasure to sail in 10-12kt winds. With a fixed keel, it ought to be a very stable boat and real pleasure to helm. Our 260 has a tiller, and while we thought we wanted a wheel, the tiller actually makes for more usable cockpit space, especially at anchor. The down side to the tiller is the almost impossibility of tying the motor to the tiller to gain some maneuverability.
Please keep this thread going, so we can share in your unique boat.
This is the prototype of the folding tiller that seems to be working well & folds up `flat`against the stern rail to permit full use of cockpit space at the slipéat anchor including full use of the helm seat.
It was made from an 8 foot piece of 1.5 inch by 3 inch oak trim epoxied together ($11) with a SS chainplate forming the `hinge` ($36) using 3/8 inch SS bolts with Nylok nuts (a bit big but the holes in the chainplate were 3/8 inch). The pivot point is on a large SS washer which forced me to space out the other bolts with smaller SS washers. I shaped the oak with a sander & finished it with tung oil.
Friction allows the tiller to be adjusted to any position, although I have a bolt with wing nut to prevent it from going too low, especially when using the tiller extension which we use 95% of the time from the corner seats. My wife prefers it over the original aluminum tube tiller as she does not have to "support it" which bothered a bad shoulder she suffers from.
The tiller is only 3 inches wide at the widest part, which forced me to shim it with 1/4 inch plywood to set it into the rudder post. I should have used 2 inch stock rather than the more readily available 1 1/2 inch oak, and may make a new thicker tiller this winter, although this tiller seems to be strong enough for the job.
I could have used a diagonal joint between the 2 pieces of the rudder wo lock it in position at the lowest point, but did not want a "sharp" edge that might damage the gelcoat on the helm seat.
