I've read where there is a rule of thumb when it comes to sheeting a Gennie or Jib sail. If you can draw an imaginary line from the center of the sail's luff to the tack of the sail, the sheet needs to be right in line with this imaginary line coming off the sheave block. Then the block can be tweaked a little one way or the other depending on how you want the sail to be shaped in relation to the set of mainsail. Bringing the block in toward the bow a little will give the sail a tighter leech and a looser foot, and visa versa.Last week I found out a 150% genoa will sheet to the cockpit coaming track when made properly. Anyone flying a 135% on an Oday 25 and to where does the sheet (block) go??
It's always helpful to know what will work on your boat so you don't have to go to the expense of making changes in hardware. We have two O'Day 25s and one O'Day 26 in our club and they all have CDI Roller Furlers. If I ever win the lottery I'm going to buy some new sails.Thanks Joe and you're right. I wanted to know if anyone was using a 135 and where that block or track ended up. I have'nt even bought the sail yet. But before I purchase a used sail, I want to know what mods will be neccessary.
It would depend entirely on how the sail is cut by the sail maker. The measurement from the bow to the sail track has to be figured into the equation along with the height of the mast and the length of the forestay and the height of the clew. The sail would be cut differently for the keel 25 with a taller mast than the c/b 25.when you're using the 135 does it sheet properly if you use the forward part of the track on the cockpit coaming. I mean is the shape real good? Ernie
You're right about that Rich. The foot on my Gennie is up swept for better visibility. It's more of a cruising Gennie. Most Gennies have a foot that is almost parallel to the deck and the sail clew is lower, whereas my sail clew is higher.It would depend entirely on how the sail is cut by the sail maker. The measurement from the bow to the sail track has to be figured into the equation along with the height of the mast and the length of the forestay and the height of the clew. The sail would be cut differently for the keel 25 with a taller mast than the c/b 25.
My 155 sheets close to the forward end of the genoa track.
Rich
