Could someone please post a few pictures showing proper rigging of the boom and of the jib sheets. I know it's really basic, but I'm not finding good information in the manual or elsewhere on the net.
Regarding the boom, it appears that perhaps the downhaul is laced through a pulley system, then up to a cleat above the boom. Is this correct? If so, what size line should I buy to string it?
For the jib: I'm not certain I've connected it properly to the bow stem. There was a snap shackle there so I attached it (see pic). It seems that the sail should rise higher up the forestay than it does. There is a good 18" to 24" of space at the top of the forestay for the sail to go higher, and it is bunched somewhat on the deck at the bottom.
Where do the jib sheets go? Do I simply run them around the outside of the shrouds?
Finally, what is the correct diameter for the main and jib sheets? My boat appears to use 7/16" and it all looks like it came off the same roll (all sheets are the same color). Is 7/16" correct, or did my previous owner just buy a bargain roll of line?
These questions might have you smiling and shaking your head, but I want to get it right and can't find hard info. Thanks for your help!
