My wind vane got very "clacky" and loose sounding when I grabbed the tower and I found a lot of play in the bearings. Cape Horn sent me a new set of bearings at no cost and this is what I found when I took things apart.
All my dealings with Cape Horn incline me to believe Yves when he says that he has never seen anything like this and he is still using the same set of bearing that he put in 20 years and two Atlantic crossings ago. There's quite a bit of rust which turned into an abrasive that wore the bearings in just three short seasons of coastal sailing. The bearings are a self lubricating plastic and he has never used any lubricant on his.
My theory is that being in an urban environment and downwind from the city results in a lot of grit. I certainly see it on my decks. I think the grit wears away the oxide layer of the stainless and the rust then grinds away the bearings.
Do you think I'm on the right track or is there something else going on?
I'm going to polish the bearing surfaces and re-passivate with Spotless Stainless. Now that I'll be spending most of my time in cleaner environments, I expect the new bearings to last considerably longer.
