Was going to do some maintenance on the Mermaid 16,500 BTU A/C unit in my 361 this weekend:
1) it says to add 5 to 10 drops of SAE non-detergent oil to the electric motor - it was not obvious where to add the oil as it had stated. I was looking for a small nipple of some kind - any suggestions?
2) went to remove/clean the air intake filter and didn't find one. I could run my fingers along the evaporator coils and could feel dust/etc. Did the best I could with a diluted solution of bleach/water and a toothbrush to clean the coils (very hard to reach). I noticed velcro down the sides of the evaporator - to hold a filter in place maybe? Also found a piece of foam like material that was about the size of the evaporator folded on the floor next to the unit - could that be the filter? It was old and literally fell apart in my hand as I picked it up.
3) Saw the thread about the condensate – I believe mine drains into the section before the bilge and collects there. Note sure if I want to add the pump or just clean with a sponge regularly.
4) Any other suggestions on maintenance? It’s getting hot here in Texas and I set the thermostat at 85 to 88 so the unit runs quite a bit. If I don’t, the boat easily gets to over 100 degrees and cannot cool down to 78 to 80 without pipes freezing. I had to have the unit serviced last summer because it stopped cooling.
