Shaft lines are more tolerant than you might think. This large powerboat was hauled in the marina today to check if something in the wheel might be the cause of vibration. It was a check, not an emergency haul out. This is the way it looked when hauled, nature took off the nuts holding the stern bearing on.
The boat has been operating nearly daily since last haul out with a professional master. The power train hasn't felt quite right but nothing indicated that anything like this could have happened. The shaft is worn about 1/16" and shows heat as well as wear damage. It wore down about 1/2" through the fiberglass and the aft end of the stern bearing casting was mushroomed over from spinning against the prop hub face. Judging from the size of the barnacles on the sternpost where the bearing flange used to be, it has been running like this for quite a while.
