Spring commissioning 2011-
At 2010 layup, I believed my raw water pump on my Westerbeke generator was just fine. However at startup yesterday, there was no water flow. Impeller inspection revealed that two blades had broken and were gone.
This failed impeller was installed on 7/20/2010 and had only 69 hours on it. The previous impeller had 245 hours on it when I replaced it last year.
The entire pump was replaced on 9/13/2007, so it has about 450 hours on it total. The shaft was tight with no discernible play so I don't suspect bad bearings. No pump leaks at all.
So what is going on here?
