I went out of my way to get a bulkhead mounted compass because I thought it looked sturdier than a bracket mounted one. I didn't want someone to bump into it and break it off the bracket or get cut on it.
I got on the boat with my nice new Mini Contest compass, and realized that the area where I need to mount it has the outside layer and the liner layer, and is separated just a little. (1/2" to 1" maybe?) Up high, right next to the companion way. I will have to cut a hole to match the compass in both layers.
Has anyone else mounted one of these on a 26S?
If so, did you do anything special to seal between the two layers?
I would rather not have to cut the liner, so I'm considering using a spacer to move the compass out just enough so that I only have to cut the outside layer.
Jim
Jim
