Hi,
I recently started to investigate why my boat takes in so much water before I decide what to do with her. I sanded the antifouling paint down to see whats underneath. So far there's plenty of chips, dings, scapes etc. I also found a couple of cracks in the trunk where the swing keel pivots. I would like to know how I should tackle them. The working area from inside would be tough, so if a ground a V out and filled all these spots with marine tex would that be sufficient. After filling and sanding and seeing if shes still sea worthy I was thinking of some barrier coat to seal her up a bit. Shes getting old and need some tlc but I want to make sure she's sound before venturing out and pouring more money into her.
Thank you
Thank you
