All,
I have a 2006 Benteau 473 which my wife and I have owned for one season. As we start our second season I want to ensure that I am keeping our batteries in the best condition possible. The boat is on its fifth year and the batteries still seem in very good shape. I have 3 4d wet cells (2 house and 1 inverter) and 2 series 27 (one starts the diesel other starts the genset). Gives me a total of 600 ahr.
We have a Freedom Marine 20 inverter / charger and a link 1000. I've been reading the manuals and forums here and I think I have most of this. I'm a little confused on a few points and could use some help clarifying.
I'm a former submarine officer so the battery charging concept and cycle is actually very similar to how we charged our batteries on my sub. I understand the bulk cycle uses full amps as the voltage builds up to 14.5 volts and then shifts into acceptance with constant voltage and reducing current until you shift to float at 13.5 volts or so for my system. Then holds 13.5 volts at small amps in float.
Here is what I'm not sure of:
Does the link system consider my battery charged when it shifts from acceptance to float? I think the manual says that the green battery lights should flash when fully charged ... but I have never seen that happen.
I know that my system is set so the charge is "complete" when the voltage is above the 13.2 v setting and amps are less than 3% (may be too high but what the previous owner had) of my capacity. But is that the point where the system shifts from acceptance to float? Or does that happen during the float cycle.
I have seen on several posts that the system also looks at the amp hours used as well. I don't think my system does this. I'm actually a bit concerned about overcharging as I can get some decent positive amp hour numbers at times when I go a few weeks between being out. I think the system is suppose to recal the CEF (mine is at 81% right now) and zero the amp hours. I know that it does zero positive amp hours as soon as the battery comes off float and starts to discharge.
Last question. Once there is some level of positive amp hours should the system come off of float and allow discharge or is it set up to constantly be on float. Back to my question of when does the link consider the charge done.
Any help would be great. I'm trying to learn as much as I can about all the systems on board.
