I am taking possession of a '76 Oday 23' with a detached cable to the swing keel. Looking for advice to re-attach while in boat yard up on a lift.
Thanks, John
John,
I'm somewhat familiar with the 1975 O'Day 25 having sailed one up from Cape Cod to our club on the Taunton River. These boats like your O'Day 23, have what is known as keel/centerboards which is very different from a swing keel. The keel on your boat is lead and the centerboard is housed in a slot in the keel and is made of fiberglass. The swing keels are generally made of cast iron or lead, and are very heavy. Both have either a metal cable or in the case of the later model O'Days, a braid centerboard pendant line.
The O'Day 25 that I sailed, had a metal cable coming off a hand winch located on the galley table pedestal. I had talked to a guy named Rudy Nickerson of D&R Marine back then about a replacement for this cable and he told me that a braid line will work on these boats just as well as a metal cable because the centerboards are pretty light.
http://www.drmarine.com/ The later model O'Day keel/centerboards have braid centerboard pendant lines that are accessed from the cockpit in front of the companionway. So I don't see why you couldn't use braid. I'm not sure what size you would need, but if you call Rudy he could probably fix you up with a braid pendant line complete with a shackle for your O'Day 23.
