Inflatables
169
Beneteau 361 Charlotte,Vt
Looking to buy a inflatable and comparing the West Marine Ru-260 against the Zodiac Typhoon 265. Both are on sale right now, the Ru-260 is $699 and the Typhoon 265 is $569 from Defender. It will be used 5 months in northern Vermont, so the PVC issue in the sun is not an issue. God knows the freaking sun does shine much in Vermont. Everything about these boats look the same. Unless someone knows something about the Zodiac I'm thinking that route and saving the $140+. Thanks
Tim R.
May 27, 2004
3,626
I have had a PVC RIB in Maine for 4 years now. Works great. I have not had to repair any punctures but it did come with a kit.
As for your original question, I believe the WM branded boats are build with thinner materials.
Mar 29, 2011
169
I believe I've made my mind up. The WM has welded seams and a five year warranty. The Zodiac is glued seams and a two year warrenty. Everything else looks the same.
caguy
Sep 22, 2006
4,004
I've had my Baltik pvc for 4 years and it is still in great shape. I had to repair it the second time out. After launching the boat, Novelman tied it to the back of the trailer and then told me to park the truck, it got dragged about 75 yds though the parking lot. The floor leaked that trip but I was able to patch with the patch kit and it is fine now. The pontoons were scratched but did not wear. I latter punctured the inflatable floor, I don't recall how, but I put a small patch on it and it has been fine for the last 3 yrs.
Macgregor 26M Delta, B.C. Canada 26M not X
I would not buy another PVC after owning mine for 5-6 years now. Even at 49 dgrees north and only having the dink out a couple months of the year and using a sun protectant the PVC still deteriorated and became tacky & sticky. I am going to try using a rubberized paint I just bought to see if I can squeeze another couple of seasons from it. The dink brand is Titan but in the USA it goes by a name Maxxon, it is a reputable brand. The PVC material just does not hold up over time even in short season northern climes, father time will take its' toll even without mother natures' sunlight. PVC is a waste of money, I won't invest in it again.
15,184
Welded or glued seams makes no difference. The fabric is the problem. PVC cannot hold up to UV degradation.
A hypalon unit may last for 15-20 years, if you get 5 years out of a PVC unit you will probably be lucky.
It is your money so go for it, but remember "we told you so". Maybe you will get lucky.
Be sure to keep it covered 24 x 7. <g>
May 7, 2006
249
Catalina 28 Mark 1 New Bern
As steve said the hypalon inflatebles will hold up. Ihave an old boat us 9.2 hypapon and have had it for over 20 years. Ilive in Ma.
Mar 29, 2011
169
Well lets see $700 for a PVC or $1900+ for Hypalon. Even if it last only 5 years, which based on what everybody is saying that own one and say they had it for 7 or more years. I can replace the pvc twice and not still paid the amount of a hypalon. I guess if have to buy three pvc over a 15 year period, I will then be to freakin old to get in a out of a dinghy anyways.
11,772
Many of the WM boats, and more specifically the RU-260, are made by Zodiac, unless that very recently changed. That said I WOULD buy the WM boat over a Zodiac because you deal with WM for warranty and NOT Zodiac who have HORRIBLE customer support.:cussing:
I won't boor you with the details but our Zodiac suffered the dreaded Zodiac "sticky tube" syndrome. Many, many Zodiac made PVC boats suffer this problem and it is like sitting on gum. Once the tubes or floor get sticky there is no fixing it. This happened within the first year IN MAINE with our Fast Roller 310. It then took three years and a lawyer to get Zodiac to honor their own written warranty..:doh:
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
didnt i read some where on this forum that hapalon had been discontinued....
regards
woody
Jun 2, 2004
5,802
The main problem with Hypalon is that you can never get rid of it so that you can buy a new one. My Avon is 20+ years old and, except for the floor, is as good as new. Well I did have to put some varnish on the wooden transom.
Nov 8, 2009
537
Hunter 386LE San Fancisco
mcrow33,
No need to pay $1900 for a generic hypalon dinghy. If you shop it you can find a new Achilles LEX 9'-6" long, 74 lb with a wood floor for a lot lower cost. I just purchased a new 2008 LEX in the box for $1100 from Sal's in Alameda, CA. I purchased this model based on the recommendation from Dinghy Specialists in southern CA for my use and the folks this forum to buy a generic hypalon material.
Woodster,
You are correct according to Achilles. Dupont, the inventor of Hypalon, is no longer producing the raw material used to make Hypalon fabric. Hypalon, which is a synthetic rubber, is now available in generic form and found in synthetic rubber coated fabrics called CSM (short for Chlorosulfonated Polyethylene Material).
Jun 4, 2004
834
Hunter 340 Forked River, NJ
I have owned and used a Zodiac Zoom PVC dinghy for well over ten+ years now. I only use it for four months in the summer but it stays in the water and out in the sun the whole time. The tubes are dirty but I can clean them with Starbrite Inflatable Boat cleaner and spray it down with 303 Protectant as recommended by Zodiac. Last season, it developed an air leak in the center tube that forms a keel under the floor boards. I think I can fix that or use one of those foam swimmy noodles as a substitute. I do cross my fingers, however, every spring when I inflate it for a air holding test. The boat spends the winter rolled up in the garage.
Mar 29, 2011
169
Thanks for everybodies input. I really didn't want to start PVC vs Hypalon fight. I really didn't care, I wasn't planning on spending over a grand on a dingy. If it wasn't for my wife I wouldn't even buy one. I would have used the hard dink that came with the boat. I just wanted to know if anybody had info about the two models that I was looking at. I bought the WM model and it's sitting the my garage. I bought the WM because of the 5 year warrenty and because they have a store ten miles from my house.
Apr 27, 2010
970
Beneteau 352 Hull #276 Ontario
Curious, did you take a look at the WM SOLSTICE Sportster Inflatable Boat??
A buddy of mine picked one up new for $499 and seems to be happy with it. At least it didn't break the bank. The only draw back would be the color.
Enjoy your new aquisition:D
Oct 29, 2005
2,366
Curiously, have anyone consider 16" tube i.s.o. 14" ones? I've a WM RU-3 PVC with 16" tube an its great! Keeps my bud dry. Most of my other sailing friends has 14" tube dinks and most ended up wet bottom by the time they got to shore.
Oct 10, 2008
277
Catalina 445 Yorktown
Once having owned a hypalon dink I was very pleased with it until one night I hit a submerged iron pipe near the shore. Lost the entire port side tube with a 10" cut. Fortunately we made it back a 1/2 mile to our anchor sailboat. No more inflateables for me. Just bought a fiberglass rowing dink with high hopes of never having to face being stranded from mother ship.
Feb 21, 2008
421
Hunter 33 Metedeconk River
Not to change the subject, but this is discussing inflatables. For only occassional use, would an inflatable like a Sevyloor FT325 be suitable? I know its PVC but it would not be out in sun except when being used for maybe a week or two per season. It would be used for really only 2-3 people. What do you think?
