As the boating season gets into full swing, a new study released by BoatU.S. Marine Insurance indicates that the leading causes of fires aboard vessels are AC & DC wiring problems, engine and transmission overheating, and fuel leaks.
Leading the pack, "AC & DC wiring/appliances" accounted for a whopping 55% of fires. The report further detailed the electrical sources into subcategories such as DC shorts/wiring (30%), DC engine regulator (12%), shore power (4%) and other causes. "Wire chafe is the biggest problem we see," adds Fort. "Electrical fires can also re-ignite even after an extinguisher has been emptied, so it's also important to have a main battery switch and/or AC breaker to stop the ignition source."
he #2 cause, "engine/transmission overheating," had 24% of the claims. Obstructed intake or exhaust cooling water passages are the main cause for hose or impeller meltdowns, which lead to overheating. Keeping these clear, especially exhaust manifolds and risers, as well as regular replacement of pump impellers, would have prevented most of these fires.
"Fuel leaks, " the #3 cause, came in with 8% of claims. Typical problem areas are fuel lines, fuel connections on the engine itself, and leaking tanks.
