During our recent haulout, we pulled the water pump from its spot under the horizontal locker cover inside the starboard lazarette, rebedded and re-attached with a new base.
At this point we noticed a tiny bit of WET at the very aft corner of this space. Apparently there is another level under this one, where there is a small space that seems like it was designed to be sealed. On our hull, the fiberglass seems to not have met all the way up with the aft seam and bulkhead, resulting in a tiny weep hole, where a tiny bit of water would slosh aft intermittently.
We drilled a 2 inch hole into this trapped compartment, only to find it full of old trapped fresh water -- one of our bolts on the hinge of the lazarette would leak in a few drops if it rained heavily -- and apprarently these drops had gathered and could not get out.
I sealed the tiny gap at the aft end of the water pump level, and vacuumed out the water from the hole we drilled, and we've been drying the inside of this small compartment with a hair dryer on a low setting.
I was wondering if anyone else who has owned a Hunter 33 Cherubini had ever had the same issue. It is about the size of a large thick hardback book.
I am considering filling it with thickened epoxy to permanently seal it.
Any ideas?
Many thanks
Bob Pullen
S/V Seanorita
Yucatan
Any ideas?
Many thanks
Bob Pullen
S/V Seanorita
Yucatan
