Also can someone tell me why I need to passify my SS.
You probably don't but, as I understand it, it's like some women (which I don't generally understand). If you annoy it, some corrective action has to be taken, the metallurgical version of candy and flowers.
It's stainless because of a thin oxide coating if forms itself, sort of like galvanizing on steel but microscopic. When this is disturbed by welding, grinding, etc. it may not reform properly especially if handled so that finger oils and contaminants get on it. Those spots will then rust. This is why you will often see rust under turnbuckle jaws and other places where there is wear.
I bought those S.S. wipes they sell in the hardware store for cleaning S.S. sinks and used them all over the boat along with a Scotchbrite pad. It worked great, the stainless looked great, for about 3 days. The more I repeated the cycle, the worse it got and the shorter it lasted. I know have a rust bucket. I figured it out when I started researching the subject.
The hardware store wipes have an acid which cleans but is destructive of the passivation. What a clever marketing concept, the more you use it, the more you will need it.
You might get acceptable results with new or modified fitting such as I am having made by cleaning them completely (which you have to do anyway for the passivating) and then letting them sit for a long time. Quicker to put the Spotless Stainless on.
http://www.mmsonline.com/articles/how-to-passivate-stainless-steel-parts
