I'm pretty sure that after previous oil changes for my Yanmar 2QM20H engine, the oil took on the typical gray/black appearance for diesel engines.
This time, even after about 40 or so hours, the oil is staying gold color, almost as new. Its probably nothing, but I'm suspicious and thought to get feedback from the forum.
The engine is running great.
The attached photo is of a paper towel I used to wipe the dipstick few times. To the right of the red outline is clean white paper. Inside the outline is the oil smear. (And also to the left of the outline since I didn't draw too well on that side.)
Other background that might be useful for the analysis:
- The oil filter is direct from the Yanmar dealer. This last time, they gave me one that physically is much smaller than the type that preceded it. However, supposedly this one has equal or better performance than the old type. Also on the filter topic, the Yanmar service manual allows that an oil filter can go 2/3 oil changes. I don't go try to go for all three allowed uses; but this is the second go-around for my current filter.
- I did have thoughts that maybe the oil pump wasn't doing its job. To check, I revved up the engine and while running, the oil level in the pan fell to the very bottom of the dipstick. I believe this indicates that oil is being sucked up and distributed around the engine normally.
- This Yanmar originally a seawater cooling design. But it was converted to anti-freeze self contained cooling with the addition of an external heat exchanger. However, because the 140-150F thermostat fitting on the exhaust manifold assembly remains, this engine runs much cooler than most.
- Since buying the boat about 4 years ago, I've changed the oil 6-8 times. I suppose its possible that if the previous owners had let the oil get very dirty, its taken this much time to finally cleanse out all the old gunk?
So, should I be concerned?
