The current set up on my Catalina 30 runs the bilge pump through the switch panel. The batteries have to be on for the float switch or the hot switch to work.
If I was to run a negative and positive lead from my battery and splice into my float switch where the hot comes in and the negative comes in would that allow for my pump to work with the batteries off?
What is the best way to wire this so the bilge pump will work with the switch on the switch panel and the float switch would work directly off the batteries?
