I am getting ready to bring my 7.5 kw genset on board for mounting. Before the engine room gets too cluttered, I would like to make the changes to the AC wiring needed to tie into the generator. Perhaps some of you can share your thoughts on how I should do this.
My shore connection consists of two 30 amp cords that tie into a 50 amp pigtail for attaching to a 50 amp socket at the dock. I assume that the two 110 volt lines feeding into the boat are not in phase, preventing me from connecting green-to-green, white-to-white, and black-to-black wires to join the two lines when a shore connection is maintained. I also assume I need multiple switches to: disconect the two 110 shore lines, and to connect the two lines to a common line coming out of the generator.
I know they sell shore power-to-generator switches that allow the shore power to be cut off and switched to the generator, all in one motion. However, it is not clear to me if switches are made to disconnect 2 separate lines from shore and join them into a single line that is switched into the generator.
You guys (and gals too) have always been patient with me. Forgive me if I am wearing that patience thin.
